Nagios XI installation failing on RHEL7 system
itsrudra
Post by itsrudra »
Hi All,
Trying to install Nagios XI, but it keeps on failing. PFA the install.log file.
I see errors like:
Execution of t/Nagios-Monitoring-Plugin-Functions-01.t aborted due to compilation errors.
# Looks like you planned 113 tests but only ran 1.
# Looks like you failed 1 test of 1 run.
# Looks like your test died just after 1.
dubious
	Test returned status 255 (wstat 65280, 0xff00)
DIED. FAILED tests 1-113
	Failed 113/113 tests, 0.00% okay
t/Nagios-Monitoring-Plugin-Functions-02......
#   Failed test 'use Nagios::Monitoring::Plugin::Functions;'
#   at t/Nagios-Monitoring-Plugin-Functions-02.t line 6.
#     Tried to use 'Nagios::Monitoring::Plugin::Functions'.
#     Error:  Can't locate Math/Calc/Units.pm in @INC (@INC contains: /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/cisco/packages/perl/perl-5.8.9/lib/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/5.8.9 /usr/cisco/packages/perl/perl-5.8.9/lib/site_perl/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/site_perl/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/site_perl/5.8.9 /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5/x86_64-linux-thread-multi /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5/x86_64-linux-thread-multi /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5 /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5/site_perl /usr/cisco/packages/cisco-perllib . /usr/cisco/packages/perl/perl-5.8.9/lib/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/5.8.9 /usr/cisco/packages/perl/perl-5.8.9/lib/site_perl/5.8.9/x86_64-linux-thread-multi /usr/cisco/packages/perl/perl-5.8.9/lib/site_perl/5.8.9 /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5/x86_64-linux-thread-multi /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5 /usr/cisco/packages/cpan-basics/perl-5.8.9/lib/perl5/site_perl /usr/cisco/packages/cisco-perllib .) at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Functions.pm line 12.
# BEGIN failed--compilation aborted at /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib/Nagios/Monitoring/Plugin/Functions.pm line 12.
# Compilation failed in require at (eval 2) line 2.
# BEGIN failed--compilation aborted at (eval 2) line 2.
Not sure if this is the issue or something else.
Regards,
Rudra
Re: Nagios XI installation failing on RHEL7 system
We haven't been able to reproduce the issue. I just tested a new install of Nagios XI 5.4.13 on RHEL 7.4 and didn't have any issues...
Is this a brand new install of Nagios XI? I see the following in the log:
useradd: user 'nagios' already exists
groupadd: group 'nagios' already exists
groupadd: group 'nagcmd' already exists
Are you using a proxy? Do you have an Internet access? Is this an offline install?
I also saw this error in the log:
Error: Can't locate Math/Calc/Units.pm in @INC...
Can you install this perl module manually via yum?
yum install perl-Math-Calc-Units -y
What is the output of the following command?
yum repolist
Can you run the command below successfully?
yum update
Please describe in details how exactly you tried to install Nagios XI. Thank you!
itsrudra
Post by itsrudra »
Hi @lmiltchev,
Yes, this is a new Nagios XI installation.
It failed once before, when i ran "yum -y install perl-Try-Tiny" and deleted /tmp/nagiosxi and tried installation again.
Are there some other files/folders that needs to be deleted before trying the installation again in addition to deleting /tmp/nagiosxi? Please share.
I'll try running the commands and provide an update
itsrudra
Post by itsrudra »
Hi @lmiltchev,
We brought up a machine with just RHEL 7 OS and then tried couple of times using
curl https://assets.nagios.com/downloads/nagiosxi/install.sh | sh
And then also tried the manual way
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./fullinstall
Manual installation failed with below error:
[root@rcdn6-vm81-108 nagiosxi]# ./fullinstall
Your system $PATH does not include /sbin and /usr/sbin. This is usually the result of installing GNOME rather than creating a clean system.
Adding /sbin and /usr/sbin to $PATH.
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been tasked with other purposes or has an
existing install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Checking MySQL credentials...
Stored MySQL password validated.
Running './0-repos'...
Configuring Repos...
Passed New Subscription Check
package centos-release is not installed
An error has occurred:
ERROR: can not find RHNS CA file: /usr/share/rhn/RHN-ORG-TRUSTED-SSL-CERT
See /var/log/up2date for more information
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/custom/epel-7/EPEL-7/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
Trying other mirror.
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/custom/linux-desktop-cisco/Packages/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/custom/linux-desktop-cisco/cisco-linux-common/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/custom/linux-desktop-cisco/cisco-linux-desktop/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/content/dist/rhel/server/7/7.30/x86_64/os/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
       You can do so in the Redhat Network web interface or using the rhn-channel command.
       or, install the yum-utils package and use the following command:
       yum-config-manager --enable rhel-7-server-optional-rpms
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
Also the yum commands you gave to run showed below messages:-
[root@rcdn6-vm81-108 /]# yum repolist
Loaded plugins: enabled_repos_upload, langpacks, package_upload, product-id, search-disabled-repos, subscription-manager
repo id        repo name        status
!Prod-ALLEN_epel-7_EPEL-7                                                   EPEL-7        12,266
!Prod-ALLEN_linux-desktop-cisco_Packages                                    Packages        5
!Prod-ALLEN_linux-desktop-cisco_cisco-linux-common                          cisco-linux-common        8
!Prod-ALLEN_linux-desktop-cisco_cisco-linux-desktop                         cisco-linux-desktop        40
epel/x86_64        Extra Packages for Enterprise Linux 7 - x86_64                                    12,427
nagios-base        Nagios        81
nagiosxi-deps                                                               Nagios XI Dependencies        27
!rhel-7-server-extras-rpms/x86_64                                           Red Hat Enterprise Linux 7 Server - Extras (RPMs)                                    778
!rhel-7-server-optional-rpms/x86_64                                         Red Hat Enterprise Linux 7 Server - Optional (RPMs)                               11,098
!rhel-7-server-rh-common-rpms/x86_64                                        Red Hat Enterprise Linux 7 Server - RH Common (RPMs)                                 228
!rhel-7-server-rpms/x86_64                                                  Red Hat Enterprise Linux 7 Server (RPMs)                                          14,619
!rhel-7-server-supplementary-rpms/x86_64                                    Red Hat Enterprise Linux 7 Server - Supplementary (RPMs)                             204
repolist: 51,781
Uploading Enabled Repositories Report
Loaded plugins: langpacks, product-id
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/content/dist/rhel/server/7/7.3/x86_64/rh-common/os/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/content/dist/rhel/server/7/7.3/x86_64/os/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/content/dist/rhel/server/7/7.3/x86_64/supplementary/os/repodata/repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
Resolving Dependencies
--> Running transaction check
---> Package epel-release.noarch 0:7-2 will be updated
---> Package epel-release.noarch 0:7-11 will be an update
---> Package nagios-repo.noarch 0:7-2.el7 will be updated
---> Package nagios-repo.noarch 0:7-3.el7 will be an update
Dependencies Resolved
 Package                                   Arch                                Version                                 Repository                                             Size
Updating:
 epel-release                              noarch                              7-11                                    Prod-ALLEN_epel-7_EPEL-7                               15 k
 nagios-repo                               noarch                              7-3.el7                                 nagios-base                                           5.5 k
Transaction Summary
Upgrade  2 Packages
Total download size: 20 k
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for Prod-ALLEN_epel-7_EPEL-7
No Presto metadata available for nagios-base
warning: /var/cache/yum/x86_64/7.30/nagios-base/packages/nagios-repo-7-3.el7.noarch.rpm: Header V4 RSA/SHA1 Signature, key ID 1e924cb3: NOKEY    ]  0.0 B/s |    0 B  --:--:-- ETA
Public key for nagios-repo-7-3.el7.noarch.rpm is not installed
(1/2): nagios-repo-7-3.el7.noarch.rpm        | 5.5 kB  00:00:30
epel-release-7-11.noarch.rpm   FAILED
https://rhn-cap-allen-4.cisco.com/pulp/repos/Prod-ALLEN/Library/CEL-PROD-7_3-DevSuite/custom/epel-7/EPEL-7/Packages/e/epel-release-7-11.noarch.rpm: [Errno 14] curl#22 - "The requested URL returned error: 504"
Error downloading packages:
  epel-release-7-11.noarch: [Errno 256] No more mirrors to try.
Internet is working fine on the site, but can this "504" failure message be due to some specific port number getting blocked that it used?
Thanks & Regards,
Rudra
Reason: Please use [code][/code] tags around terminal output
npolovenko
Post by npolovenko »
@itsrudra, Looks like you need to enable the optional repo channel. Please run these commands to enable it and try the manual installation one more time:
yum install yum-utils
itsrudra
Post by itsrudra »
Hi @npolovenko
Tried running the yum install yum-utils, but it failed with below error
[root@rcdn6-vm81-108 /]# yum install yum-utils
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Errno 14] curl#22 - "The requested URL returned error: 504"
One of the configured repositories failed (EPEL-7),
and yum doesn't have enough cached data to continue. At this point the only
safe thing yum can do is fail. There are a few ways to work "fix" this:
1. Contact the upstream for the repository and get them to fix the problem.
2. Reconfigure the baseurl/etc. for the repository, to point to a working
upstream. This is most often useful if you are using a newer
distribution release than is supported by the repository (and the
packages for the previous distribution release still work).
3. Run the command with the repository temporarily disabled
yum --disablerepo=Prod-ALLEN_epel-7_EPEL-7 ...
4. Disable the repository permanently, so yum won't use it by default. Yum
will then just ignore the repository until you permanently enable it
again or use --enablerepo for temporary usage:
yum-config-manager --disable Prod-ALLEN_epel-7_EPEL-7
or
subscription-manager repos --disable=Prod-ALLEN_epel-7_EPEL-7
5. Configure the failing repository to be skipped, if it is unavailable.
Note that yum will try to contact the repo. when it runs most commands,
so will have to try and fail each time (and thus. yum will be be much
slower). If it is a very temporary problem though, this is often a nice
compromise:
yum-config-manager --save --setopt=Prod-ALLEN_epel-7_EPEL-7.skip_if_unavailable=true
failure: repodata/repomd.xml from Prod-ALLEN_epel-7_EPEL-7: [Errno 256] No more mirrors to try.
[root@rcdn6-vm81-108 /]# yum-config-manager --enable rhel-7-server-optional-rpms
=============================================================== repo: rhel-7-server-optional-rpms ===============================================================
[rhel-7-server-optional-rpms]
async = True
bandwidth = 0
base_persistdir = /var/lib/yum/repos/x86_64/7.30
baseurl = https://rhn-cap-allen-4.cisco.com/pulp/ ... ptional/os
cache = 0
cachedir = /var/cache/yum/x86_64/7.30/rhel-7-server-optional-rpms
check_config_file_age = True
compare_providers_priority = 80
cost = 1000
deltarpm_metadata_percentage = 100
deltarpm_percentage =
enabled = True
enablegroups = True
exclude =
failovermethod = priority
ftp_disable_epsv = False
gpgcadir = /var/lib/yum/repos/x86_64/7.30/rhel-7-server-optional-rpms/gpgcadir
gpgcakey =
gpgcheck = True
gpgdir = /var/lib/yum/repos/x86_64/7.30/rhel-7-server-optional-rpms/gpgdir
gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-redhat-release
hdrdir = /var/cache/yum/x86_64/7.30/rhel-7-server-optional-rpms/headers
http_caching = all
includepkgs =
ip_resolve =
keepalive = True
keepcache = False
mddownloadpolicy = sqlite
mdpolicy = group:small
mediaid =
metadata_expire = 1
metadata_expire_filter = read-only:present
metalink =
minrate = 0
mirrorlist =
mirrorlist_expire = 86400
name = Red Hat Enterprise Linux 7 Server - Optional (RPMs)
old_base_cache_dir =
password =
persistdir = /var/lib/yum/repos/x86_64/7.30/rhel-7-server-optional-rpms
pkgdir = /var/cache/yum/x86_64/7.30/rhel-7-server-optional-rpms/packages
proxy = http://proxy.esl.cisco.com:80
proxy_dict = {'ftp': 'http://proxy.esl.cisco.com:80', 'http': 'http://proxy.esl.cisco.com:80', 'https': 'http://proxy.esl.cisco.com:80'}
proxy_password =
proxy_username =
repo_gpgcheck = False
retries = 10
skip_if_unavailable = False
ssl_check_cert_permissions = True
sslcacert = /etc/rhsm/ca/katello-server-ca.pem
sslclientcert = /etc/pki/entitlement/8571083155404531056.pem
sslclientkey = /etc/pki/entitlement/8571083155404531056-key.pem
sslverify = True
throttle = 0
timeout = 30.0
ui_id = rhel-7-server-optional-rpms/x86_64
ui_repoid_vars = basearch
username =
[root@rcdn6-vm81-108 /]# wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
--2018-03-26 02:24:46-- http://assets.nagios.com/downloads/nagi ... est.tar.gz
Resolving assets.nagios.com (assets.nagios.com)... 2600:3c00::f03c:91ff:fedf:b821, 72.14.181.71
Connecting to assets.nagios.com (assets.nagios.com)|2600:3c00::f03c:91ff:fedf:b821|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://assets.nagios.com/downloads/nag ... est.tar.gz [following]
--2018-03-26 02:24:46-- https://assets.nagios.com/downloads/nag ... est.tar.gz
Connecting to assets.nagios.com (assets.nagios.com)|2600:3c00::f03c:91ff:fedf:b821|:443... connected.
Length: 55354889 (53M) [application/x-gzip]
Saving to: ‘xi-latest.tar.gz’
100%[=======================================================================================================================>] 55,354,889 26.7MB/s in 2.0s
2018-03-26 02:24:49 (26.7 MB/s) - ‘xi-latest.tar.gz’ saved [55354889/55354889]
[root@rcdn6-vm81-108 /]# tar xzf xi-latest.tar.gz
[root@rcdn6-vm81-108 /]# cd nagiosxi
or has an existing install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Errno 14] curl#22 - "The request ed URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Errno 1 4] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [E rrno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Err no 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Er rno 14] curl#22 - "The requested URL returned error: 504"
https://rhn-cap-allen-4.cisco.com/pulp/ ... repomd.xml: [Errno 14] cu rl#22 - "The requested URL returned error: 504"
Passed Optional Repo Check
epel-release RPM installed OK
Repo configured OK
RESULT=0
Running './1-prereqs'...
Installing prerequisites...
: search-disabled-repos, subscription-manager
or
compromise:
RESULT=1
INSTALLATION ERROR!
The script that failed was: './1-prereqs'
You have new mail in /var/spool/mail/root
It looks like this server has a repo setup that is not responding, per the error output below I would suggest
