NCPA and NAT
FranckB1
NCPA and NAT
Post by FranckB1 »
I'm trying to understand how Nagios can manage to monitor remote hosts, located behind routers with a single public IP address, using Nat and port forwarding.
It's quite easy to specify a port number when using the check_ncpa plugin, in order to be translated towards the right host inside the remote network, but how Nagios manages the repsonses to determine from which host they come from.
Do we need to set a specific port for responses, in the NCPA configuration of each host ?
And how do we configure Nagios for making him able to match each response with the right host ?
Apologizes if my demand could seem to be trivial, but I haven't found any accurate response on this topic until now.
Thanks for help.
Re: NCPA and NAT
Nagios uses the host and service definition to know what check applies to what in the interface, so this wouldn't be an issue. With active checks, you could try something like this: translate ip:555 -> host1:5693 and ip:556 -> host2:5693, etc.
The question is, why complicate things? You could simply use passive checks.
Here's the NCPA documentation on passive checks:
https://www.nagios.org/ncpa/help.php#passive
Once the passive check results show up in the Unconfigured Objects, you can simply run the Unconfigured Passive Object wizard to set them up in Nagios XI. For more information on monitoring unconfigured objects, please review the document below:
https://assets.nagios.com/downloads/nag ... ith_XI.pdf
Hope this helps.
FranckB1
Re: NCPA and NAT
Post by FranckB1 »
Hi, and thank you so much for your response.
I've already considered to use passive checks for these kind of configuration (and already tested it, works fine...).
However, the main drawback of passive checks is that they are.... passive. Which implies that if the remote host is down, you'll never be sent an alert for it.
That's why I was looking for a solution to proceed active checks through internet towards private networks...
I understand what you mean, but where, in Nagios, can I set these translations ?
Thanks for help.
Re: NCPA and NAT
Post by mcapra »
FranckB1 wrote:Which implies that if the remote host is down, you'll never be sent an alert for it.
Not necessarily. Here's the official documentation for passive checks:
https://assets.nagios.com/downloads/nag ... hecks.html
Nagios Core has a concept of a given check's "freshness". Essentially, if your machines don't phone home within a certain amount of time, their check results are flagged as "stale" and you can alert/notify on this condition. More info:
https://assets.nagios.com/downloads/nag ... hness.html
kyang
Re: NCPA and NAT
Post by kyang »
Thanks @mcapra!
FranckB1
Re: NCPA and NAT
Post by FranckB1 »
Thanks @mcapra !
Really useful. I just tested it. It works fine !
FranckB1
Re: NCPA and NAT
Post by FranckB1 »
Thanks for help.
Any help about this ?
Thanks in advance.
Re: NCPA and NAT
Thanks for help.
Thanks in advance.
This was an example suggestion on how you could setup NAT on your router, it was not a Nagios or NCPA setup
