Upgrading from 2014R2.6 to 5.4.1 not working
martinkuriax
Post by martinkuriax »
We are trying to upgrade our Nagios XI from version 2014R2.6 to Version:5.4.13
But we are getting the error below (Public key for nmap-6.47-1.x86_64.rpm is not installed):
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/spool/perfdata: file changed as we read it
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up MySQL databases...
Backing up PostgresQL databases...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/autoupgrade_backup..tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
Downloading Latest Nagios XI Tarball...
Archive:  sourceguardian/ixed4.lin.x86-64.zip
  inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [  OK  ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 10.96.180.15 for ServerName
[  OK  ]
Checking required prereqs...
Please wait...
OLD VERSION: 415
Loaded plugins: fastestmirror, security
Setting up Remove Process
Resolving Dependencies
--> Running transaction check
---> Package rpmforge-release.x86_64 0:0.5.3-1.el6.rf will be erased
http://apt.sw.be/redhat/el6/en/x86_64/rpmforge/repodata/repomd.xml: [Errno 14] PYCURL ERROR 6 - "Couldn't resolve host 'apt.sw.be'"
Trying other mirror.
Dependencies Resolved
 Package                Arch         Version              Repository       Size
Removing:
 rpmforge-release       x86_64       0.5.3-1.el6.rf       installed        13 k
Transaction Summary
Remove        1 Package(s)
Installed size: 13 k
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
  Erasing    : rpmforge-release-0.5.3-1.el6.rf.x86_64                       1/1
  Verifying  : rpmforge-release-0.5.3-1.el6.rf.x86_64                       1/1
Removed:
Complete!
Determining fastest mirrors
 * base: mirror.liquidtelecom.com
 * epel: mirror.wbs.co.za
 * extras: mirror.liquidtelecom.com
 * updates: mirror.liquidtelecom.com
Setting up Install Process
Package automake-1.11.1-4.el6.noarch already installed and latest version
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
---> Package nmap.x86_64 2:5.51-4.el6 will be updated
---> Package nmap.x86_64 2:6.47-1 will be an update
---> Package php-mbstring.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-mbstring.x86_64 0:5.3.3-49.el6 will be an update
--> Processing Dependency: php-common(x86-64) = 5.3.3-49.el6 for package: php-mbstring-5.3.3-49.el6.x86_64
---> Package subversion.x86_64 0:1.6.11-15.el6_7 will be installed
--> Processing Dependency: libneon.so.27()(64bit) for package: subversion-1.6.11-15.el6_7.x86_64
---> Package neon.x86_64 0:0.29.3-3.el6_4 will be installed
--> Processing Dependency: libpakchois.so.0()(64bit) for package: neon-0.29.3-3.el6_4.x86_64
---> Package php-common.x86_64 0:5.3.3-40.el6_6 will be updated
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-mysql-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-gd-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-xml-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-snmp-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-pgsql-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-ldap-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-pdo-5.3.3-40.el6_6.x86_64
--> Processing Dependency: php-common(x86-64) = 5.3.3-40.el6_6 for package: php-cli-5.3.3-40.el6_6.x86_64
---> Package php-common.x86_64 0:5.3.3-49.el6 will be an update
---> Package pakchois.x86_64 0:0.4-3.2.el6 will be installed
---> Package php.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-cli.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-cli.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-gd.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-gd.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-ldap.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-ldap.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-mysql.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-mysql.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-pdo.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-pdo.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-pgsql.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-pgsql.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-snmp.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-snmp.x86_64 0:5.3.3-49.el6 will be an update
---> Package php-xml.x86_64 0:5.3.3-40.el6_6 will be updated
---> Package php-xml.x86_64 0:5.3.3-49.el6 will be an update
Installing:
 subversion        x86_64      1.6.11-15.el6_7         base               2.3 M
Updating:
 nmap              x86_64      2:6.47-1                nagiosxi-deps      5.1 M
 php-mbstring      x86_64      5.3.3-49.el6            base               460 k
Installing for dependencies:
 neon              x86_64      0.29.3-3.el6_4          base               119 k
 pakchois          x86_64      0.4-3.2.el6             base                21 k
Updating for dependencies:
 php               x86_64      5.3.3-49.el6            base               1.1 M
 php-cli           x86_64      5.3.3-49.el6            base               2.2 M
 php-common        x86_64      5.3.3-49.el6            base               530 k
 php-gd            x86_64      5.3.3-49.el6            base               111 k
 php-ldap          x86_64      5.3.3-49.el6            base                43 k
 php-mysql         x86_64      5.3.3-49.el6            base                86 k
 php-pdo           x86_64      5.3.3-49.el6            base                80 k
 php-pgsql         x86_64      5.3.3-49.el6            base                75 k
 php-snmp          x86_64      5.3.3-49.el6            base                36 k
 php-xml           x86_64      5.3.3-49.el6            base               108 k
Transaction Summary
Install       3 Package(s)
Upgrade      12 Package(s)
Total download size: 12 M
Total                                           1.2 MB/s |  12 MB     00:09
warning: rpmts_HdrFromFdno: Header V4 RSA/SHA1 Signature, key ID c62934a0: NOKEY
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS
Importing GPG key 0x1E924CB3:
 Userid : Nagios Enterprises, LLC (RPM Development) <[email protected]>
 Package: nagios-repo-6-2.el6.noarch (installed)
Re: Upgrading from 2014R2.6 to 5.4.1 not working
It seems like you tryied to upgrade from the web UI. Have you tried to upgrade from the CLI, too?
How did you install the "old" XI (2014R2.6) - from source, using one of our pre-built VMs, from rpm? Is this an offline install? Are you using a proxy? Are you using custom/local repos?
If RHEL, you can usually import a missing key by running:
rpm --import /path/to/YOUR-RPM-GPG-KEY
What keys do you have in the "/etc/pki/rpm-gpg/" directory?
ls -la /etc/pki/rpm-gpg/
You can also try to set the following in your repos:
gpgcheck=0
Run:
yum clean all
yum update
then try to upgrade Nagios XI once again.
martinkuriax
It worked! thanks, God bless
I have changed gpgcheck=0 in my repos
Then Ran:
#yum clean all
#yum update
and did the upgrade from the CLI
#wget -O upgrade.sh https://assets.nagios.com/downloads/nagiosxi/upgrade.sh
#sh ./upgrade.sh
Nagios XI Upgrade Complete!
You can access the Nagios XI web interface by visiting:
http://10.xx.yy.xx/nagiosxi/
[root]#
Now I have the latest version of Nagios
Your Nagios XI installation is up to date.
Latest Available Version: 5.4.13
Installed Version: 5.4.13
Last Update Check: 2018-04-04 12:46:15
I am glad I could help! :) Can we close this topic and mark it as resolved? Thanks!
