Changing context of CGI files for SELinux
ALTAES
Post by ALTAES »
I currently have Nagios 4.3.4 successfully running on the server (it has a PID),
but I get a Whoops error on the web interface
It's a packet installed version of nagios on a redhat 7
# nagios -v nagios.cfg :
Nagios Core 4.3.4
Last Modified: 2017-08-24
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
        Checked 445 services.
        Checked 117 hosts.
        Checked 24 host groups.
        Checked 0 service groups.
        Checked 1 contacts.
        Checked 4 contact groups.
        Checked 14 commands.
        Checked 6 time periods.
        Checked 0 host escalations.
        Checked 117 hosts
        Checked 0 host dependencies
        Checked 6 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
# systemctl restart nagios :
[1522066961] LOG VERSION: 2.0
[1522066961] qh: Socket '/var/spool/nagios/cmd/nagios.qh' successfully initialized
[1522066961] qh: core query handler registered
[1522066961] nerd: Channel hostchecks registered successfully
[1522066961] nerd: Channel servicechecks registered successfully
[1522066961] nerd: Channel opathchecks registered successfully
[1522066961] nerd: Fully initialized and ready to rock!
[1522066961] wproc: Successfully registered manager as @wproc with query handler
[1522066961] wproc: Registry request: name=Core Worker 6832;pid=6832
[1522066961] wproc: Registry request: name=Core Worker 6834;pid=6834
[1522066961] wproc: Registry request: name=Core Worker 6831;pid=6831
[1522066961] wproc: Registry request: name=Core Worker 6833;pid=6833
[1522066961] Successfully launched command file worker with pid 6835
# more nagios.cfg :
log_file=/var/log/nagios/nagios.logcfg_dir=/etc/nagios/hosts
cfg_dir=/etc/nagios/hostgroups
cfg_dir=/etc/nagios/services
cfg_dir=/etc/nagios/servicegroups
cfg_dir=/etc/nagios/contacts
cfg_dir=/etc/nagios/contactgroups
cfg_dir=/etc/nagios/timeperiods
cfg_dir=/etc/nagios/templates
cfg_dir=/etc/nagios/commands
object_cache_file=/var/spool/nagios/objects.cache
precached_object_file=/var/spool/nagios/objects.precache
resource_file=/etc/nagios/private/resource.cfg
status_file=/var/log/nagios/status.dat
status_update_interval=10
nagios_user=nagios
nagios_group=nagios
check_external_commands=1
command_file=/var/spool/nagios/cmd/nagios.cmd
lock_file=/var/run/nagios/nagios.pid
temp_file=/var/spool/nagios/nagios.tmp
temp_path=/tmp
event_broker_options=-1
log_rotation_method=d
log_archive_path=/var/log/nagios/archives
use_syslog=1
log_notifications=1
log_service_retries=1
log_host_retries=1
log_event_handlers=1
log_initial_states=0
log_current_states=1
log_external_commands=1
log_passive_checks=1
max_service_check_spread=30
service_interleave_factor=s
max_host_check_spread=30
max_concurrent_checks=0
check_result_reaper_frequency=10max_check_result_reaper_time=30check_result_path=/var/spool/nagios/checkresultsmax_check_result_file_age=3600cached_host_check_horizon=15
cached_service_check_horizon=15
soft_state_dependencies=0
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
service_check_timeout=60
host_check_timeout=30
event_handler_timeout=30
notification_timeout=30
ocsp_timeout=5
perfdata_timeout=5
retain_state_information=1
state_retention_file=/var/log/nagios/retention.dat
retention_update_interval=60
use_retained_program_state=1
retained_host_attribute_mask=0retained_service_attribute_mask=0retained_process_host_attribute_mask=0
retained_process_service_attribute_mask=0retained_contact_host_attribute_mask=0
interval_length=60
check_for_updates=1
bare_update_check=0
execute_service_checks=1
execute_host_checks=1
accept_passive_host_checks=1
enable_notifications=1
enable_event_handlers=1
process_performance_data=0obsess_over_services=0
obsess_over_hosts=0
check_for_orphaned_services=1
check_for_orphaned_hosts=1
check_service_freshness=1
service_check_timeout_state=c
check_host_freshness=0
host_freshness_check_interval=60additional_freshness_latency=15enable_flap_detection=1
low_host_flap_threshold=5.0
high_host_flap_threshold=20.0
date_format=usillegal_object_name_chars=`~!$%^&*|'"<>?,()=
use_regexp_matching=0
use_true_regexp_matching=0
admin_email=nagios@localhost
admin_pager=pagenagios@localhost
daemon_dumps_core=0
enable_environment_macros=0
debug_level=0
debug_verbosity=1
debug_file=/var/log/nagios/nagios.debug
max_debug_file_size=1000000
allow_empty_hostgroup_assignment=0
Thank you.
Re: Nagios running, Whoops error on web interface
make sure selinux is in permissive mode
https://support.nagios.com/forum/viewto ... 81#p213037
ALTAES
Post by ALTAES »
It was, indeed, my SELinux mode that was blocking the CGI.
I've set it on permissive, instead of enforcing. However, this just postpone the problem.
I'd like to have it on enforcing, and to have Nagios running at the same time, wich mean that I need to change the
context of the CGI file.
Here is the current ones :
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/archivejson.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/avail.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/cmd.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/config.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/extinfo.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/histogram.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/history.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/notifications.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/objectjson.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/outages.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/showlog.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/status.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/statusjson.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/statusmap.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/statuswml.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/statuswrl.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/summary.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/tac.cgi
-rwxrwxr-x. nagios nagios system_u:object_r:nagios_script_exec_t:s0 /usr/lib64/nagios/cgi-bin/trends.cgi
But when I try to change it, I got an error :
# semanage fcontext -a -t httpd_sys_script_exec_t /usr/lib64/nagios/cgi-bin/
   ValueError: File spec /usr/lib64/nagios/cgi-bin/ conflicts with equivalency rule '/usr/lib64 /usr/lib'; Try adding '/usr/lib/nagios/cgi-bin/' instead.
I'm really not a great selinux configurer, but it looks like there is already a conflicting context set.
I'll leave the thread open so another user can chime in if they know how to resolve this.
