Custom view or dashboard to hide services/hosts with comment
chaoscreater
Post by chaoscreater »
Hi all,
I'm trying to figure out if there is a way to filter out services and hosts that have a comment associated with them. I can get Nagios to display all hosts and services that are showing as critical or unhandled, using the following:
http://NagiosHost/nagios/cgi-bin/status ... ustypes=15
But I'm having trouble hiding entries with a comment. I could acknowledge them, but that's not the point. We add comments and acknowledge services/hosts depending on the situation.
Re: Custom view or dashboard to hide services/hosts with com
The only one I know of is this view
/nagios/cgi-bin/extinfo.cgi?type=3
chaoscreater
I know about that one too, but that just shows all services/hosts with comments. I want to show the opposite and only for services/hosts that are critical or have unhandled problems.
Core does not have another at this time, if you or your company write one please contribute it to the project here
https://github.com/NagiosEnterprises/nagioscore
Thanks!
