Monitoring a website and expected content
emartine
Post by emartine »
I am trying to monitor the Nagios XI main web page content.
I can log in as the nagios test user I created and I am expecting it to read the content "Nagios XI" as it shows up on the main page. See attached.
My understanding from the check that is running via the wizards is that the check runs as follows:
/usr/local/nagios/libexec/check_http -H servername -s "Nagios XI" -f ok -I <serverIP> -u "/nagiosxi/" -S -p 443 -a "<username>:<password>"
Unfortunately the response I get back is:
HTTP CRITICAL: HTTP/1.1 302 Found - string 'Nagios XI' not found on 'https://servername:443/nagiosxi/' - 629 bytes in 0.175 second response time |time=0.174792s;;;0.000000 size=629B;;;0
Am I doing this right? Perhaps this isn't the best way to monitor website content?
The reason for doing this is to ensure that the main page shows what is expected and not just availability.
Re: Monitoring a website and expected content
302 is a redirection
change -f ok to -f follow
emartine
Post by emartine »
Awesome the follow works. This commands logs in as the test account I created but does it log out? If it doesn't... how can I make it log out?
It's only "logged in" in the sense that XI would remember the user if you sent the cookie back, since you aren't storing the cookie, you are essentially logged out, nothing else to do.
emartine
Post by emartine »
Thank you for that info. How would I monitor a web page that is flash based? Is that possible?
emartine
Post by emartine »
Scott. I sent you a PM.
send response in PM, but the gist was the page being monitored didn't use Basic Authentication so the command as being used would not work. May have to build a complex check using the Web Transaction Wizards, or something more complicated
emartine
Post by emartine »
I used the web transaction wizard and ensured that the stanzas were closed. But there still appears to be an issue.
There is a line that says could not find ParserDetails.ini in /usr/lib64/perl5/XML/SAX
./webinject.pl -c filename_config.xml
Starting WebInject Engine...
Test: filename_test.xml - 1
Login page
Passed HTTP Response Code Verification (not in error range)
TEST CASE PASSED
Response Time = 0.907 sec
Test: filename_test.xml - 2
Sign in
TEST CASE PASSED
Response Time = 0.853 sec
Start Time: Thu Apr 5 10:36:56 2018
Total Run Time: 1.816 seconds
Test Cases Run: 2
Test Cases Passed: 2
Test Cases Failed: 0
Verifications Passed: 2
Verifications Failed: 0
Is there a way to verify that the check is working correctly?
This looks correct.
emartine wrote:There is a line that says could not find ParserDetails.ini in /usr/lib64/perl5/XML/SAX
you may just need to re-install the package
yum install perl-XML-SAX -y
emartine wrote: Is there a way to verify that the check is working correctly?
Best way I can think of is have it test for something that shouldn't exist and see if it fails one of the steps, or give it bad credentials and it should fail the login
emartine
Post by emartine »
Even with credentials reworded all tests pass.
