How to adjust Fusion NOC frames and their positions?
- too small, not wide enough
- badly positioned
How to adjust Fusion NOC frames (too small, not wide enough)
Re: How to adjust Fusion NOC frames (too small, not wide eno
Are you able to increase the resolution on your screen? These appear to be hardcoded but you changing the resolution should take care of it. You could also add these dashlets to custom dashboard where they can be resized as needed.
it will be nice if we had available the same NOC screen is available in Nagios XI
I have the same problem.
adjusting the size, resolution is just a work around. or adding it to custom is just extra work and end end is not as nice and effective as the one in Nagios XI
I filed an internal bug report on the issue (task_id=13259). Our developers will be looking into this as soon as they can. Thank you!
Thank you for confirmingbosecorp wrote:tnks
Please close the case
