ping Monitoring of POS mobile devices using Nagios core
Shareef
Post by Shareef »
Can somebody can confirm availability monitoring is feasible using Nagios core for following devices.
1. Store Tills( Android based Store POS Mobiles )
2. POS Devices
thank you,
Shareef Ahamed
Re: ping Monitoring of POS mobile devices using Nagios core
I'm sure it may be possible depending on what the device exposes, but you may need to write your own plugin
I'll leave the thread open for other responses but here are the plugin development guidelines that can be used to create your own custom plugins
https://nagios-plugins.org/doc/guidelines.html
