Polling a cisco interface - beyond 50mb the graph shows zero
vijilants
Post by vijilants »
System:
Nagios XI Version : 5.4.11
londnms1 2.6.32-431.29.2.el6.i686 i686
CentOS release 6.5 (Final)
Gnome Installed
Can someone please advise on the problem below:
When the bandwidth utilization goes above 50mb on a ciscio interface, the bandwidth graph on nagios shows zero bandwidth usage. If I lower the traffic rate below 50mb on the interface, the graph starts registering.
Note I am running SNMPv2 and I have done a manual SNMP walk on the mib and I can see thespecific interface counters increment.
Many Thanks
Re: Polling a cisco interface - beyond 50mb the graph shows
Did you configure this using the stock Switch/Router wizard?
vijilants
Post by vijilants »
scottwilkerson wrote:Did you configure this using the stock Switch/Router wizard?
Yes I did, but this was showing zero for about 2 hours and then suddenly burst in to life.
Not sure as to exactly what is going on.
Maybe there really wasn't much traffic?
Can we consider this closed?
vijilants
Post by vijilants »
Yes, You may close it.
Thank you
