NCPA 2.1.3 Process Count Check Problem
numje009
Post by numje009 »
The following process count check was working fine in NCPA 2.0.5 on a Windows 2008 Client :
$ /usr/local/nagios/libexec/check_ncpa.py -H ctelpsa345 -t 'xxxxx' -P 5693 -M 'process/TC2m.exe/-c1:'
OK: Process count for processes named tc2m.exe was 1 | 'process_count'=1;;;
But it's no longer working since upgrading to NCPA 2.1.3 :
$ /usr/local/nagios/libexec/check_ncpa.py -H ctelpsa344 -t 'xxxxx' -P 5693 -M 'process/TC2m.exe/-c1:'
The node (process) requested does not exist. You may be trying to access the 'processes' node.
I have attached a copy of the ncpa_listener.log in debug mode.
Re: NCPA 2.1.3 Process Count Check Problem
The "old" syntax won't work. You would need to modify your check to look something like this:
/usr/local/nagios/libexec/check_ncpa.py -H ctelpsa344 -t 'xxxxx' -P 5693 -M 'processes' -c 1: -q 'exe=TC2m,match=regex'
or this:
/usr/local/nagios/libexec/check_ncpa.py -H ctelpsa344 -t 'xxxxx' -P 5693 -M 'processes' -c 1: -q 'name=TC2m.exe,match=search'
The new syntax would provide you with more info - not only the process count, but also CPU and Memory.
numje009
Post by numje009 »
That works perfectly, even with older client version 2.0.5.
Thank You!
I am glad I could help! :) Is it ok to lock this topic? Thanks!
numje009
Post by numje009 »
Yes! Thanks!!!
