Offline installation of NRPE on Solaris 11.3
btsmnagios
Hello, I have been tasked with installing NRPE on a Solaris 11.3 system, I have very limited knowledge of Solaris and I have followed your documentation for the workaround to install NRPE but it broke ssh and ssl, when adding the symlinks. I have now resolved that issue but would you be able to provide a documented offline way to install NRPE to Solaris 11, thanks
Re: Offline installation of NRPE on Solaris 11.3
This is the doc that I am aware of which doesn't suggest any symlinks that I see
https://support.nagios.com/kb/article.p ... 15#Solaris
I will add that Solaris is and has always been a challenge. We do not run any Solaris systems in house
btsmnagios
thanks for not helping, I will struggle, you can close the ticket
Is this the doc you had followed?
We do have Solaris 11 instructions there
