Email Config
colbyhart
Email Config
Post by colbyhart »
I can't seem to get Nagios to login to my SMTP server to send mail no matter what config I use. I have the server relay allowed. Can anyone give me suggestions?
Re: Email Config
does your SMTP server require authentication?
If not, make sure the username and password fields are blank and security set to none
colbyhart
Re: Email Config
Post by colbyhart »
I tried that and it doesn't work. Here is the msg.
A test email was sent to [email protected]
Mailer said: SMTP Error: Could not connect to SMTP host. (method=smtp;host=hchexchange.hch.local;port=25;security=none)
An error occurred sending a test email!
Re: Email Config
You have to be sure that you have all of the proper information entered. Also, make sure that port 25 is not blocked. You can try:
# telnet hchexchange.hch.local 25
If you are not able to connect, you will get:
telnet: Unable to connect to remote host: Connection timed out
otherwise, you will have:
Connected to ... (...).
Escape character is '^]'.
colbyhart
Re: Email Config
Post by colbyhart »
fixed
