I am going to install the Nagios Core 4.3.4 on centOS 7
Can anyone suggest me with the document to setup the Email Notification in Nagios Core 4.3.4 ?
Setup the Email Notification in Nagios Core
amitgupta19
npolovenko
- Support Tech
Re: Setup the Email Notification in Nagios Core
@amitgupta19, There're many various ways to set up email notifications on Nagios Core depending on your requirements. Are you going to be using an SMTP server or Sendmail, or would you like to use a Gmail/Yahoo account instead? Here're a few links:
http://sharadchhetri.com/2013/07/16/how ... ment-18916
https://awaseroot.wordpress.com/2013/02 ... ns-puppet/
http://www.telnetport25.com/2012/02/con ... gios-core/
amitgupta19
We have the Exchange server setup in our environment.
Would like to use that.
http://www.telnetport25.com/2012/02/con ... gios-core/ has some specifics for Exchange environments. Did you have a specific part you're having issues with? The article didn't go into much detail regarding postfix config though so if that is the problem you may need to research a bit to find how to get it to work in your environment. http://www.techspacekh.com/configuring- ... -centos-7/ seems to be a good source.
amitgupta19
I am able to set it up now.
This thread can be closed.
Thanks for the support
Glad to hear!
