I just started a trial of Fusion and I have successfully fused two Nagios Core 4.3.4 instances. The install was great, but I am have issues with Dashlets. I'm a beginner-level, any advice, help is appreciated.
Using the Development Guide, I created the "Show Outputs" Dashlet. Once I added the dashlet to a dashboard, it states "loading dashlet..." but it never fully loads. It seems to be stuck loading. Any ideas?
I'm also have trouble with the Perfgraph Dashlet. I was able to add the server type for "core", but now it cannot authenticate. Does anyone have a version of this dashlet that will work with a Core instance?
-A
Nagios Core <-> Nagios Fusion Perfgraph Dashlet
adam.larkins
Re: Nagios Core <-> Nagios Fusion Perfgraph Dashlet
I'm not sure what you mean by the Show Outputs dashlet, can you show how you are adding this?adam.larkins wrote:Using the Development Guide, I created the "Show Outputs" Dashlet. Once I added the dashlet to a dashboard, it states "loading dashlet..." but it never fully loads. It seems to be stuck loading. Any ideas?
In Fusion 4.1.2 we have a "Performance Graphs" dashlet, but it only works with XI, not Coreadam.larkins wrote:I'm also have trouble with the Perfgraph Dashlet. I was able to add the server type for "core", but now it cannot authenticate. Does anyone have a version of this dashlet that will work with a Core instance?
