XI Cent OS 7.0 upgrade issue from Cent OS 5.7
comeonyoyo
Hi Guys
Originally I use CentOS release 5.7 (Final), XI Version : 2014R2.7
Now I have to upgrade to Cent OS 7.0 cos OS 5 doesn`t support TLS 1.2
I`ve installed a new CentOS Linux release 7.0.1406 (Core) XI Version : 2014R2.7.
And restores the old OS 5 backup successfully.
Now I can access http://X.X.X.X/nagios/
But can`t access http://X.X.X.X/nagiosxi/
It shows
Forbidden
You don't have permission to access /nagiosxi/ on this server
Does anyone encounter this situation ? any solution?
Thank you in advance
It shows
Forbidden
comeonyoyo
XI install error in Cent OS 7.X
Hi Guys
I`ve installed a new nagios XI Version : 2014R2.7. to CentOS Linux release 7.2, 7.3 ,7.4
But they all showed the error : The script that failed was `./ E-importnagiosql`
Please help to see how can solve the problem ,thanks^^
Re: XI Cent OS 7.0 upgrade issue from Cent OS 5.7
Your first post accessing the Nagios XI GUI could be caused by a Apache Configuration issue.
Try this, login to the server as root and run the following command.
Then try and access the XI GUI. Post the output of the tail command so we can view the errors.
Post the Apache configuration files as well so we can check them.
In the folder where you extracted the XI source installer, there should be an install.log file.
Can you post that so we can view the full installation log?
tail -f /var/log/httpd/*_logPost the Apache configuration files as well so we can check them.
/etc/httpd/conf/httpd.conf
/etc/httpd/conf.d/nagiosxi.conf
/etc/httpd/conf.d/ssl.confCan you post that so we can view the full installation log?
comeonyoyo
Hi
The attchment is the output, pls help to see, thank you
This error
http://httpd.apache.org/docs/2.4/upgrading.html#access
If not, I will need you to copy these files
from the Nagios server and upload them to the post so I can check the settings.
Is an Apache configuration issue and if you want to try and fix the issue on your server, you can take a look at this link for instructions.AH01630: client denied by server configuration:
/etc/httpd/conf.d/ssl.confBe sure to check out our Knowledgebase for helpful articles and solutions!
comeonyoyo
Here is the output, pls help to check where should be modified, thank you
lets change your nagiosxi.conf to
Then restart https
<Directory "/usr/local/nagiosxi/html">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
Require all granted
</Directory>
Alias /nagiosxi "/usr/local/nagiosxi/html"
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
systemctl restart httpd-
comeonyoyo
WoW , It works .. I can access it right now.
This command ''Require all granted'' fixs it.
Thank you very much.. wish you have a wonderful day~
Glad that was the trick.
Locking as Resolved.
