Grafana integration
lpereira
Grafana integration
Post by lpereira »
Hello all...
I have installed Grafana and Graphite on a separate server, is not installed on the same Nagios Box. However i'm not finding the way to read the Nagios XI Data. Is there any procedure for that? i have searched but all the info i found is related to Grafana installed on the same box with Nagios.
Help is much appreciated.
regards.
Re: Grafana integration
lpereira
Post by lpereira »
Sorry for the delay on my response. But according to this procedure, grafana is integrated on the same Nagios VM. I want to have both instances on different servers.
lpereira wrote:Sorry for the delay on my response. But according to this procedure, grafana is integrated on the same Nagios VM. I want to have both instances on different servers.
I'm sure this is possible but as we have not documented nor tested this yet you would need to work through the process.
lpereira
Post by lpereira »
i followed a procedure for Centreon, is possible to get both intances separately. Centreon has a connection Broker for Grafana... however this option seems not to be avaibale for XI.
lpereira wrote:i followed a procedure for Centreon, is possible to get both intances separately. Centreon has a connection Broker for Grafana... however this option seems not to be avaibale for XI.
I cannot speak for the features of Centreon, but Nagios doesn't have a Grafana broker that has been tested with XI
