According to Microsofts counter type definition (see https://blogs.msdn.microsoft.com/psssql ... _counters/) the "Average Wait Time (ms)" counter is of type PERF_AVERAGE_BULK, and should be measured from two samples.
Currently, as far as i understand, the "Average Wait Time" in the Script check_mssql_server.py, Version 2.1.0, 06/24/2016, is calculated from only one sample of counter "Average Wait Time (ms)" directly divided by counter "Average Wait Time Base". See attached picture.
Is there a chance that you could update the plugin so this metric is calculated more accurate?
check_mssql_server.py "Average Wait Time"
Setup from image nagiosxi-5.4.13-64.ova.
System:
Nagios XI Version : 5.4.13
XXX.local 2.6.32-696.20.1.el6.x86_64 x86_64
CentOS release 6.9 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
System:
Apache Information
PHP Version: 5.3.3
Re: check_mssql_server.py "Average Wait Time"
Would you be willing to make an issue on the public tracker for this open source plugin?
https://github.com/NagiosEnterprises/ch ... collection
I could copy over your info, but you seem informed about the Microsoft specs, and I would like you to get credit for the find.
Thank you for the fast reply, i just posted the issue on GitHub.
System:
Apache Information
PHP Version: 5.3.3
System:
Apache Information
PHP Version: 5.3.3
Thanks! Locking thread
