Nagios XI - Apply Configuration Never Completes
MOHANREDDY
I am attempting to Apply Configuration and i'm seeing the following output:
* Configuration submitted for processing...
* Waiting for configuration verification..................
The configuration never applies, the page may be timing out.
When tailing the log /usr/local/nagiosxi/var/cmdsubsys.log
/usr/local/nagiosxi/scripts/export_nagiosql.sh: line 7: 6658 Killed sudo $BASEDIR/reset_config_perms.sh
RESETTING CONFIG PERMS FAILED!\n
OUTPUT=RESETTING CONFIG PERMS FAILED!\n
RETURNCODE=4
PROCESSED 1 COMMANDS
PROCESSED 0 COMMANDS
when i run ./reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=S6lY6NVWpF9T' -O nagiosql.login--2018-04-17 11:31:13-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... 127.0.0.1
Connecting to localhost (localhost)|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: 'nagiosql.login'
[ <=> ] 34,272 --.-K/s in 0.01s
2018-04-17 11:31:14 (3.22 MB/s) - 'nagiosql.login' saved [34272]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
Another reconfigure process is still running, sleeping...
RETURNCODE=4
CMDLINE
LOGIN SUCCESSFUL!
Array
Re: Nagios XI - Apply Configuration Never Completes
Can you show the output of the following
grep NAGIOS /etc/sudoers-
MOHANREDDY
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
Lets run this
Then also send back the results of the following
cd/usr/local/nagiosxi/scripts/
rm -f reconfigure_nagios.lock
./reconfigure_nagios.shCode: Select all
chage -l nagios-
MOHANREDDY
++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++scottwilkerson wrote:Lets run thisThen also send back the results of the followingCode: Select all
cd/usr/local/nagiosxi/scripts/ rm -f reconfigure_nagios.lock ./reconfigure_nagios.shCode: Select all
chage -l nagios
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=S6lY6NVWpF9T' -O nagiosql.login--2018-04-17 12:09:46-- http://localhost/nagiosxi/includes/components/ccm/
2018-04-17 12:09:47 (3.21 MB/s) - 'nagiosql.login' saved [34272]
LOGIN SUCCESSFUL!
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=S6lY6NVWpF9T' -O nagiosql.login--2018-04-17 12:09:47-- http://localhost/nagiosxi/includes/components/ccm/
2018-04-17 12:09:47 (3.34 MB/s) - 'nagiosql.login' saved [34272]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: 'nagiosql.export.monitoring'
[ <=> ] 22,008 --.-K/s in 0.008s
2018-04-17 12:09:48 (2.77 MB/s) - 'nagiosql.export.monitoring' saved [22008]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'Local Disk Usage' on host 'localhost'
Error: Could not register service (config file '/usr/local/nagios/etc/services/server.cfg', starting on line 63)
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1523978282.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1523978282.tar.gz
RESETTING PERMS
chage -l nagios
Last password change : Apr 13, 2018
Password expires : Jul 12, 2018
Password inactive : never
Account expires : never
Minimum number of days between password change : 7
Maximum number of days between password change : 90
Number of days of warning before password expires : 7
MOHANREDDY
Now i am seeing database errors
more mariadb.log
180413 11:12:38 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
180413 11:12:38 [Note] /usr/libexec/mysqld (mysqld 5.5.52-MariaDB) starting as process 5397 ...
180413 11:12:38 InnoDB: The InnoDB memory heap is disabled
180413 11:12:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180413 11:12:38 InnoDB: Compressed tables use zlib 1.2.7
180413 11:12:38 InnoDB: Using Linux native AIO
180413 11:12:38 InnoDB: Initializing buffer pool, size = 128.0M
180413 11:12:38 InnoDB: Completed initialization of buffer pool
InnoDB: The first specified data file ./ibdata1 did not exist:
InnoDB: a new database to be created!
180413 11:12:38 InnoDB: Setting file ./ibdata1 size to 10 MB
InnoDB: Database physically writes the file full: wait...
180413 11:12:38 InnoDB: Log file ./ib_logfile0 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile0 size to 5 MB
180413 11:12:38 InnoDB: Log file ./ib_logfile1 did not exist: new to be created
InnoDB: Setting log file ./ib_logfile1 size to 5 MB
InnoDB: Doublewrite buffer not found: creating new
InnoDB: Doublewrite buffer created
InnoDB: 127 rollback segment(s) active.
InnoDB: Creating foreign key constraint system tables
InnoDB: Foreign key constraint system tables created
180413 11:12:38 InnoDB: Waiting for the background threads to start
180413 11:12:39 Percona XtraDB (http://www.percona.com) 5.5.49-MariaDB-38.0 started; log sequence number 0
180413 11:12:39 [Note] Plugin 'FEEDBACK' is disabled.
180413 11:12:39 [Note] Server socket created on IP: '0.0.0.0'.
180413 11:12:39 [Note] Event Scheduler: Loaded 0 events
180413 11:12:39 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.5.52-MariaDB' socket: '/var/lib/mysql/mysql.sock' port: 3306 MariaDB Server
180413 11:13:35 [Note] /usr/libexec/mysqld: Normal shutdown
180413 11:13:35 [Note] Event Scheduler: Purging the queue. 0 events
180413 11:13:36 InnoDB: Starting shutdown...
180413 11:13:36 InnoDB: Shutdown completed; log sequence number 1601170
180413 11:13:36 [Note] /usr/libexec/mysqld: Shutdown complete
180413 11:13:36 mysqld_safe mysqld from pid file /var/run/mariadb/mariadb.pid ended
180413 11:13:37 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
180413 11:13:37 [Note] /usr/libexec/mysqld (mysqld 5.5.52-MariaDB) starting as process 8950 ...
180413 11:13:37 InnoDB: The InnoDB memory heap is disabled
180413 11:13:37 InnoDB: Mutexes and rw_locks use GCC atomic builtins
180413 11:13:37 InnoDB: Compressed tables use zlib 1.2.7
180413 11:13:37 InnoDB: Using Linux native AIO
180413 11:13:37 InnoDB: Initializing buffer pool, size = 128.0M
180413 11:13:37 InnoDB: Completed initialization of buffer pool
180413 11:13:37 InnoDB: highest supported file format is Barracuda.
180413 11:13:37 InnoDB: Waiting for the background threads to start
180413 11:13:38 Percona XtraDB (http://www.percona.com) 5.5.49-MariaDB-38.0 started; log sequence number 1601170
180413 11:13:38 [Note] Plugin 'FEEDBACK' is disabled.
180413 11:13:38 [Note] Server socket created on IP: '0.0.0.0'.
180413 11:13:38 [Note] Event Scheduler: Loaded 0 events
180413 11:13:38 [Note] /usr/libexec/mysqld: ready for connections.
more mariadb.log
Those don't look related and are from 4 days ago
However there is an error in a config
Go to CCM -> Services
Config Template select <config form error>
click the disk icon next to any of the services
When you get the output, the service definition that begins on line 63 has an issue.
This may be the same service but also 'Local Disk Usage' on localhost has Invalid max_attempts, check_interval, retry_interval, or notification_interval
these will need to be addressed in the CCM and then the rerun
./reconfigure_nagios.sh-
MOHANREDDY
I have corrected those errors but still the is still loading on for a long time and passingscottwilkerson wrote:Those don't look related and are from 4 days ago
these will need to be addressed in the CCM and then the rerunCode: Select all
Apply Configuration
Waiting for configuration verification......................................................................................................
Apply Configuration
Reset config permissions failed.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Try Again View Snapshot
Show Written Configs
Error: Contact 'user' has no service notification commands defined!
I corrected the error and ran from ./reconfigure.sh from server and i didn't see any error
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=S6lY6NVWpF9T' -O nagiosql.login--2018-04-17 16:06:27-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 38,275 --.-K/s in 0.01s
2018-04-17 16:06:27 (3.27 MB/s) - 'nagiosql.login' saved [38275]
LOGIN SUCCESSFUL!
Array
RESETTING PERMS
CMDLINE
2018-04-17 16:06:28 (3.49 MB/s) - 'nagiosql.login' saved [38275]
LOGIN SUCCESSFUL!
CMDLINE:
--2018-04-17 16:06:28-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 21,806 --.-K/s in 0.008s
2018-04-17 16:06:28 (2.68 MB/s) - 'nagiosql.export.monitoring' saved [21806]
OUTPUT:
Nagios Core 4.2.4
License: GPL
Checking objects...
Checked 20 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 2 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
But i click apply configuration from GUI its throwing the same error as above
Apply Configuration
Apply Configuration
Please try running the following and report the results
sudo su nagios -c '/usr/local/nagiosxi/scripts/reset_config_perms.sh'
echo $?-
MOHANREDDY
it changed the permissions of all the directories you specified and the output for echo $? is "0".
