i have configured some hosts dependent on a "X" host. but when that "X" host goes down/unreachable those dependent hosts are also raising alerts.
I want that dependent hosts checks & notification should fail when "X" host is down. but that's not working.
Also, same with services- configured some services dependent on a "Y" service.
I want that dependent service checks & notification should fail when "Y" service is critical/warning but that's not working.
can somebody guide me?
check below dependency configs.
define hostdependency {
# config_name local2
dependent_host_name local4,local5,local6
host_name local2
inherits_parent 0
execution_failure_criteria u,d,p,
notification_failure_criteria u,d,
dependency_period xi_timeperiod_24x7
define servicedependency {
# config_name local12
dependent_host_name local8
dependent_service_description CPU Usage, Memory Usage
host_name local12
service_description cpu
inherits_parent 1
execution_failure_criteria w,u,c,p,
notification_failure_criteria w,u,c,p,
Host / services dependencies are not working
Re: Host / services dependencies are not working
I think you may have them backwards
https://assets.nagios.com/downloads/nag ... ncies.html
In each definition you specify the dependent service, the service you are depending on, and the criteria (if any) that cause the execution and notification dependencies to fail (these are described later).
You can create several dependencies for a given service, but you must add a separate service dependency definition for each dependency you create.
