Nesting Host groups for organization
ajnagiosadmin
Post by ajnagiosadmin »
Not sure if this can even be done but would like to organize my hostgroups by "categories". Here's my example..
Say you want to separate the state by Counties and Cities, you would have:
HostGroup Seminole Orange
Hosts Altamonte Springs Orlando
Hosts Sanford Goldenrod
Hosts Longwood Apopka
So now, you want to then create groups of counties by state which would give you:
HostGroup Florida
Is there a way to make a group of counties contained in a master group of a state? Basically I want the hostgroup page in nagios to display (what would be equal to) the states which when clicked will go to the sublist of counties.
Hope that makes sense.
jsmurphy
Re: Nesting Host groups for organization
Post by jsmurphy »
Hostgroups can be members of other hostgroups so you should have no problem configuring it the way you are suggesting :)
All you need to do is use the hostgroup_members directive inside the parent hostgroup definition, more information here: http://nagios.sourceforge.net/docs/3_0/ ... #hostgroup
