Hello Team,
We are following below PDF link document to install Nagios XI monitoring on AWS Instance
https://assets.nagios.com/downloads/nag ... -Cloud.pdf
We can able to access link http://<Public-IP-Address>/nagiosxi ( Through Public IP we can able to access), but when we try to configure with private IP we can't able to access link.
Is there any other methods to install Nagios XI on AWS.
Not able to Access Nagios XI link through Private IP on AWS
Re: Not able to Access Nagios XI link through Private IP on
When it is configured with the private IP, are you trying to access it from another machine within the same private network? It should work in this case but not if the client is on a different network.
