I am getting is below mentioned Error while installing nagios log server on Ubuntu 16.04 LTS .
Can someone help me here to resolve this issue.?
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'prereqs'
Getting Error while installing nagios log server
kyang
Re: Getting Error while installing nagios log server
Currently, Nagios Log Server is only supported on RHEL/CentOS.
https://assets.nagios.com/downloads/nag ... Server.pdf
We recommend installing on a clean system as well.
Thanks Kyang for letting me know this. I thought it's available for Ubuntu also.
kyang
No problem.
Are we okay to close this forum thread?
You can go ahead.
