Event Handlers
aregis1973
Event Handlers
Post by aregis1973 »
We have a host (Windows 2008) with a service (IIS) and created a command for the event handler. Below is the information on the command.
       command_name                             check_iiswebserver_handler
       command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_iiswebserver
Information for the Service
        host_name                       HOST
        service_description             IIS Web Server
        use                             xiwizard_windowsserver_nsclient_service
        check_command                   check_xi_service_nsclient!!SERVICESTATE!-l W3SVC -d SHOWALL!!!!!
        max_check_attempts              10
        check_interval                  1
        retry_interval                  1
        event_handler                   check_iiswebserver_handler
        event_handler_enabled           1
        notification_interval           60
        contacts                        user
        contact_groups                  Administrators
        register                        1
Here's the script for the check_iiswebserver.bat in the host.
net start W3SVC
Below is the NSC.ini file.
[modules]
NRPEListener.dll
NSClientListener.dll
CheckWMI.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
NRPEListener.dll
CheckExternalScripts.dll
NRPEClient.dll
[crash]
[Settings]
allowed_hosts=xx.xx.xx.xx
use_file=1
[log]
[NSClient]
[NRPE]
[Check System]
[External Script]
allow_arguments=1
script_dir=C:\Program Files\NSClient++\scripts
[Script Wrappings]
vbs=cscript.exe //T:30 //NoLogo scripts\lib\wrapper.vbs %SCRIPT% %ARGS%
ps1=cmd /c echo scripts\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
bat=scripts\%SCRIPT% %ARGS%
[External Scripts]
check_iiswebserver=scripts\check_iiswebserver.bat
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual
type=paged type=page
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_disk_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-
unreadable
alias_volumes=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
alias_volumes_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
ignore-unreadable
alias_service=checkServiceState CheckAll
alias_service_ex=checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver
HPZ12" exclude=stisvc
alias_process=checkProcState "$ARG1$=started"
alias_process_stopped=checkProcState "$ARG1$=stopped"
alias_process_count=checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
alias_process_hung=checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
alias_event_log=CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1
"filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source !=
'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%
count%)"
alias_file_size=CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1
"syntax=%filename% %size%" max-dir-depth=10
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1
"syntax=%filename% %write%"
alias_sched_all=CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%"
warn=>0
alias_sched_long=CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -
$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_sched_task=CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%
alias_updates=check_updates -warning 0 -critical 0
check_ok=CheckOK Everything is fine!
[Wrapped Scripts]
[NSCA Agent]
[NSCA Commands]
[NRPE Client Handlers]
check_other=-H 192.168.0.1 -p 5666 -c remote_command -a arguments
Event handler runs fine without arguments but we need to pass arguments $SERVICESTATE$ $SERVICESTATETYPE$ but unable to do so.
Are there any other setups needed for this?
Thanks.
Re: Event Handlers
aregis1973 wrote:Hi,
[External Scripts]
[/code]
Thanks.
You would need to add these to the check command as well as the NSC.ini something like this
       command_line                             $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_iiswebserver -a '-s $SERVICESTATE$ -t $SERVICESTATETYPE$'
and NSC.ini
[External Scripts]
check_iiswebserver=scripts\check_iiswebserver.bat $ARG1$
or something like that and then you will need to add the handeling of the args in the check_iiswebserver.bat file
