Error in Bulk Renaming
Getting this error after bulk rename. Right after finish making changes and while trying to apply config
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - N: Usage'' at line 1
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - O: Usage'' at line 1
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - R: Usage'' at line 1
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - V: Usage'' at line 1
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - W: Usage'' at line 1
SQL Error [ndoutils] : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') AND `name2`='Check Service Drive - X: Usage'' at line 1
Bulk Renaming Tool
Complete
The new config is being applied in the background and on large systems can take some time.
Bulk Renaming Tool
Complete
Re: Error in Bulk Renaming
It;s addition to the error, looks like this created a big problem for me now. Looks like the files didnt get renamed
npolovenko
- Support Tech
Hello, @bosecorp.
What exactly did you try to rename? Did you use any special characters in the new name?
In XI web interface please go to Configure -> Core Configurations Manager, then click on Tools -> Config File Management in the left column. Then perform the following actions in order:
1)Write
2)Delete
3)Write
4)Verify
If you see any errors please copy-paste the output in here.
You could also revert to a previous working Configuration Snapshot in Core Configurations Manager. And after you revert run the database repair script:
1)Write
2)Delete
3)Write
4)Verify
/usr/local/nagiosxi/scripts/repair_databases.sh As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
No errors
I was trying to rename services.
looks like the services got renamed successfully, but like I said the files didn't get rename so now all my historical information is gone from the GUI perspective. I know the old performance data is there, just with the wrong file name
npolovenko
- Support Tech
@ bosecorp, So the services in GUI were renamed but the RRD files did not get renamed? As a result, you're unable to see any performance data?
Please check a few service files in this directory and let me know if they were not renamed.
What version of XI are you running and have you upgraded it recently?
Try to revert to a previous good snapshot, run the database repair script and then attempt to rename the services again.
/usr/local/nagios/share/perfdata/Try to revert to a previous good snapshot, run the database repair script and then attempt to rename the services again.
correct, no perfdata
cant restore from snapshop at this point. almost 3 days have gone by. We have added a bunch of new host of other things.
and yes the RRD file didnt get renamed.
I am running 5.4.12. havent upgrade Nagios in the last several weeks
npolovenko
- Support Tech
@bosecorp, How many services did you rename with the Bulk Renaming Tool? 5, 50? If it's only 5-10 you could attempt manually rename the RRD files. Let me know.
yea...we've had issues with large renames as well. We only do 25 or so at a time now.bosecorp wrote:Thousands
I like graphs...
npolovenko
- Support Tech
@Ehamby, This makes it more complicated. Theoretically, you could take a VM snapshot of Nagios XI, then revert back to a previous CCM snapshot and try to rename the services again. If the renaming succeeds this time copy the renamed RRD files from (/usr/local/nagios/share/perfdata/) folder to your computer, or copy the whole folder. Then revert to a VM snapshot and replace the perfdata folder.
All the other solutions will be too time-consuming provided that you need to modify thousands of services.
I agree with @Ehamby, In future, I would try to rename no more than 500 at a time. Modifying thousands of services requires more resources and tweaking the config files, including the php.ini.
