i'm trying to monitor linux server.
i installed by referring to https://assets.nagios.com/downloads/nag ... e/NRPE.pdf
at first i got, SSl handshake failed. i troubleshooted. later i am getting error as "NRPE: Command 'check_disk' not defined"
referred many topics with this error but, but they didn't help.
On the client machine
/usr/local/nagios/libexec/check_nrpe -H localhost -t 30 -c check_users -a '-w 5 -c 10'
USERS OK - 3 users currently logged in |users=3;5;10;0
/usr/local/nagios/libexec/check_nrpe -H localhost -t 30 -c check_disk -a ' -w 85 -c 90 /usr'
on the GUI also the same error exists
I have attached the nrpe.conf file
MOHANREDDY
MOHANREDDY
Re: NRPE: Command 'check_disk' not defined
when i change the command to monitor root its working, where as its not working on /opt file system
/usr/local/nagios/libexec/check_nrpe -H localhost -t 30 -c check_hda2 -a ' -w 85 -c 90 /dev/mapper/sysvg-lv_opt'
NRPE: Command 'check_hda2' not defined
command[check_hda2]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/mapper/sysvg-lv_optCode: Select all
host_name server
service_description /opt Disk Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_hda2!-a '-w 20% -c 10% -p /dev/mapper/sysvg-lv_opt'!!!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
notifications_enabled 1
contacts herbert,Mohan Mummadi
_xiwizard linux-server
register 1
npolovenko
- Support Tech
Hello, @MOHANREDDY.
Looks like you do not have a check_disk command defined in your nrpe.cfg file. Edit the file->Find the following paragraph:
And add this line underneath:
Save the file and restart the nrpe service.
command[check_load]=/usr/local/nagios/libexec/check_load -r -w .15,.10,.05 -c .30,.25,.20
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/mapper/sysvg-lv_root
command[check_total_procs]=/usr/local/nagios/libexec/check_procs -w 150 -c 200Code: Select all
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
MOHANREDDY
Its working and thanks for the help
Glad to hear it! Are we good to close this up then?
MOHANREDDY
yes, you can thanks for the help
