Suggestion: Make import search box case insensitive
Product suggestion: Make the search menu in the import configs screen case-insensitive. Spent a few minutes puzzled, trying to figure out why "ImportFile.cfg" wasn't found when I was searching for "importfile" instead.
Re: Suggestion: Make import search box case insensitive
That makes sense and would be helpful. It will be case insensitive in XI 5.5.
More bubbles for you!
