I have an ironport check,check_ironport.pl, that returns correct and valid messages when run from the command line, and from the "Run check command" in the CCM. When I apply the check and view it in Nagios XI, I recieve:
mgw-1.ardclb.uta.edu;Workqueue;UNKNOWN;HARD;5;(No output on stdout) stderr:
Thats it. No message after the "stderr:". My apologies, but I had to pull it from the nagios.log. I couldn't get the picture to insert.
Check command is:
#!/usr/bin/perl -w
# check_ironport.pl
# Copyright (C) 2011-2013 Stefan Heumader <[email protected]>
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
use strict;
use warnings;
use File::Basename;
use Getopt::Long;
use Net::SNMP;
# Main values
my $PROGNAME = basename($0);
my $VERSION = '1.0';
my $TIMEOUT = 5;
my $DEBUG = 0;
# Nagios exit states
my %states = (
OK => 0,
WARNING => 1,
CRITICAL => 2,
UNKNOWN => 3,
# Nagios state names
my %state_names = (
0 => 'OK',
1 => 'WARNING',
2 => 'CRITICAL',
3 => 'UNKNOWN',
# SNMP Data
my %oids = (
# SYSTEM
'perCentMemoryUtilization' => '1.3.6.1.4.1.15497.1.1.1.1',
'perCentCPUUtilization' => '1.3.6.1.4.1.15497.1.1.1.2',
'memoryAvailabilityStatus' => '1.3.6.1.4.1.15497.1.1.1.7', # 1 OK, 2 WARNING, 3 CRITICAL
'openFilesOrSockets' => '1.3.6.1.4.1.15497.1.1.1.19',
# POWER SUPPLY
'powerSupplyRedundancy' => '1.3.6.1.4.1.15497.1.1.1.8.1.3', # 1 OK, 2 NOT OK
'powerSupplyStatus' => '1.3.6.1.4.1.15497.1.1.1.8.1.2', # 1 NOT INSTALLED, 2 HEALTHY, 3 NoAC, 4 FAULTY
# RAID
'raidStatus' => '1.3.6.1.4.1.15497.1.1.1.18.1.2', # 1 HEALTHY, 2 FAILURE, 3 REBUILD
'raidLastError' => '1.3.6.1.4.1.15497.1.1.1.18.1.4',
# ENVIRONMENT
'degreesCelsius' => '1.3.6.1.4.1.15497.1.1.1.9.1.2',
# FEATURE KEYS & UPDATES
'keySecondsUntilExpire' => '1.3.6.1.4.1.15497.1.1.1.12.1.2', # seconds to expire
# MAIL SPECIFIC
'c-workQueueMessages' => '1.3.6.1.4.1.15497.1.1.1.11', # amount of emails in workqueue
'c-queueAvailabilityStatus' => '1.3.6.1.4.1.15497.1.1.1.5', # 1 OK, 2 WARNING, 3 CRITICAL
'c-resourceConservationReason' => '1.3.6.1.4.1.15497.1.1.1.6', # 1 OK, 2 MEMORY; 3 QUEUE SHORTAGE, 4 QUEUE FULL
'c-perCentQueueUtilization' => '1.3.6.1.4.1.15497.1.1.1.4',
'c-oldestMessageAge' => '1.3.6.1.4.1.15497.1.1.1.14', # seconds of oldest message in queue
'c-mailTransferThreads' => '1.3.6.1.4.1.15497.1.1.1.20',
my $o_verb = undef;
my $o_help = undef;
my $o_version = undef;
my $o_host = undef;
my $o_port = 161;
my $o_community = undef;
my $o_snmpversion = undef;
my $o_timeout = 5;
my $o_warn = undef;
my $o_crit = undef;
my $o_category = undef;
my $o_licence = undef;
my @licence_categories = ();
# FUNCTIONS
sub p_version ()
print "$PROGNAME version: $VERSION\n";
sub p_usage ()
print "$PROGNAME usage: $0 [-v] -H <host> [-s <snmpversion>] -C <SNMPv12 Community|SNMPv3 password> [-p <port>] -w <warning_level> -c <critical_level> [-t <timeout>] [-V] -x <category> [-l <comma seperated licence items>]\n";
sub p_help ()
print "\ncheck_ironport.pl - SNMP Ironport monitor PlugIn for Nagios in version $VERSION\n";
print "Copyright (C) 2011-2013 Stefan Heumader <stefan\@heumader.at>\n\n";
p_usage();
print <<EOF;
-h, --help
print this help message
-V, --version
prints version number of Nagios PlugIn
-v, --verbose
print extra debug informations
-H, --hostname=HOST
name or IP address of host to check
-C, --community=COMMUNITY NAME
SNMPv2 community name for the host's SNMP agent
SNMPv3 user password
-P, --port=PORT
SNMP port (default 161)
-s, --snmpversion=VERSION
SNMP version (default 2)
-w, --warn=INTEGER
warning threshold (necessary)
-c, --crit=INTEGER
critical threshold (necessary)
-x, --category=STRING
defines which information should be read (...)
-l, --licence=STRING
comma septerated list of licence items
EOF
sub verbose ($)
my $a = $_[0];
print "$a\n" if defined($o_verb);
sub check_options ()
Getopt::Long::Configure ("bundling");
GetOptions(
'v' => \$o_verb, 'verbose' => \$o_verb,
'h' => \$o_help, 'help' => \$o_help,
'V' => \$o_version, 'version' => \$o_version,
'H:s' => \$o_host, 'hostname:s' => \$o_host,
'p:i' => \$o_port, 'port:i' => \$o_port,
'C:s' => \$o_community, 'community:s' => \$o_community,
's:i' => \$o_snmpversion, 'snmpversion:i' => \$o_snmpversion,
't:i' => \$o_timeout, 'timeout:i' => \$o_timeout,
'w:s' => \$o_warn, 'warn:s' => \$o_warn,
'c:s' => \$o_crit, 'critical:s' => \$o_crit,
'x:s' => \$o_category, 'category:s' => \$o_category,
'l:s' => \$o_licence, 'licence:s' => \$o_licence,
if (defined($o_help))
p_help();
exit $states{"UNKNOWN"};
if (defined($o_version))
p_version();
unless (defined($o_host))
print "No host specified!\n";
p_usage();
unless (defined($o_community))
print "No community string specified!\n";
p_usage();
if (defined($o_snmpversion))
if ($o_snmpversion != 1 && $o_snmpversion != 2 && $o_snmpversion != 3)
print "Invalid SNMP version specified!\n";
p_usage();
else
$o_snmpversion = 2;
if ($o_category eq 'keySecondsUntilExpire' && defined($o_licence))
@licence_categories = split(',', $o_licence);
elsif ($o_category eq 'keySecondsUntilExpire' && !defined($o_licence))
print "No licence keys specified!\n";
p_usage();
unless (defined($o_warn) && defined($o_crit))
print "No warning or critical thresholds specified!\n";
p_usage();
# delete % characters if any
$o_warn =~ s/\%//g;
$o_crit =~ s/\%//g;
# validate category input
my $valid_cat = 0;
foreach (keys %oids)
if ($o_category eq $_)
$valid_cat = 1;
unless ($valid_cat)
print "Invalid category specified!\n";
p_usage();
# MAIN
check_options();
if (defined($TIMEOUT))
verbose("Alarm at $TIMEOUT + 5");
alarm($TIMEOUT+5);
else
verbose("No timeout defined!\nAlarm at $o_timeout + 10");
alarm ($o_timeout+10);
# Connect to Host
my %snmpconfig = (
-hostname => $o_host,
-version => $o_snmpversion,
-port => $o_port,
-timeout => $o_timeout,
if ($o_snmpversion == 1 || $o_snmpversion == 2)
$snmpconfig{'-community'} = $o_community;
elsif ($o_snmpversion == 3)
$snmpconfig{'-username'} = 'v3get';
$snmpconfig{'-authpassword'} = $o_community;
my ($session, $error) = Net::SNMP->session(%snmpconfig);
unless (defined($session))
print ("ERROR: opening SNMP session: $error\n");
exit $states{'UNKNOWN'};
if ($DEBUG)
my $mask = 0x02;
$mask = $session->debug([$mask]);
# Read Result
my $result = $session->get_table(
-baseoid => $oids{$o_category}
unless (defined($result))
print "ERROR: ".$session->error()."\n";
$session->close;
my $value = 0;
my @results = ();
foreach (keys %$result)
verbose("OID: $_, Desc: $$result{$_}");
unless ($$result{$_} eq "endOfMibView")
if ($o_category eq 'raidLastError')
$value = $$result{$_} if $$result{$_} ne 'No Errors';
elsif ($o_category eq 'keySecondsUntilExpire')
my $tmp = $$result{$_};
my @results = grep(/$tmp/, @licence_categories);
$value = 9999999; # we need to set it to a really high value ...
if (grep(/$tmp/, @licence_categories))
my $new_oid = $_;
$new_oid =~ s/1.3.6.1.4.1.15497.1.1.1.12.1.2/1.3.6.1.4.1.15497.1.1.1.12.1.4/;
my $result2 = $session->get_request(
-varbindlist => [$new_oid,],
foreach (keys %$result2)
verbose("OID: $_, Desc: $$result2{$_}");
$$result2{$new_oid} = int($$result2{$new_oid}/86400);
print STDERR $$result2{$new_oid}."\n";
$value = $$result2{$new_oid} if $$result2{$new_oid} < $value;
else
$value = $$result{$_} if $$result{$_} > $value;
$session->close;
my $exit_code = $states{"OK"};
if ($value eq 'No Errors' || $value eq 'ACTIVE' || $value eq '0')
print "SNMP $o_category OK: $value\n";
else
print "SNMP $o_category CRITICAL: $value\n";
$exit_code = $states{'CRITICAL'};
if ($value > $o_warn)
print "SNMP $o_category OK: $value > $o_warn\n";
elsif ($value > $o_crit)
print "SNMP $o_category WARNING: $value > $o_crit\n";
$exit_code = $states{'WARNING'};
else
print "SNMP $o_category CRITICAL: $value < $o_crit\n";
elsif ($o_category eq 'memoryAvailabilityStatus' || $o_category eq 'c-queueAvailabilityStatus')
if ($value == 1)
print "SNMP $o_category OK: $value = 1\n";
elsif ($value == 2)
print "SNMP $o_category WARNING: $value = 2\n";
elsif ($value == 3)
print "SNMP $o_category CRITICAL: $value = 3\n";
elsif ($o_category eq 'powerSupplyRedundancy')
if ($value == 1)
elsif ($value == 2)
print "SNMP $o_category CRITICAL: $value = 2\n";
elsif ($o_category eq 'c-resourceConservationReason')
if ($value == 1)
elsif ($value == 2 || $value == 3)
print "SNMP $o_category WARNING: $value = 2 (MEMORY)\n" if $value == 2;
print "SNMP $o_category WARNING: $value = 3 (QUEUE SHORTAGE)\n" if $value == 3;
elsif ($value == 4)
print "SNMP $o_category CRITICAL: $value = 4 (QUEUE FULL)\n";
elsif ($o_category eq 'raidStatus')
if ($value == 1)
elsif ($value == 2)
print "SNMP $o_category CRITICAL: $value = 2 (FAILURE)\n";
elsif ($value == 3)
print "SNMP $o_category WARNING: $value = 3 (REBUILD)\n";
elsif ($o_category eq 'powerSupplyStatus')
if ($value == 2)
print "SNMP $o_category OK: $value = 2 (HEALTHY)\n";
elsif ($value == 3)
print "SNMP $o_category WARNING: $value = 3 (NoAC)\n";
elsif ($value == 4)
print "SNMP $o_category CRITICAL: $value = 4 (FAULTY)\n";
else
print "SNMP $o_category CRITICAL: $value > $o_crit|$o_category=$value;$o_warn;$o_crit\n";
elsif ($value > $o_warn)
print "SNMP $o_category WARNING: $value > $o_warn|$o_category=$value;$o_warn;$o_crit\n";
else
print "SNMP $o_category OK: $value < $o_warn|$o_category=$value;$o_warn;$o_crit\n";
exit $exit_code;
[[email protected] ~]$ /usr/local/nagios/libexec/check_ironport.pl -H mgw-1.ardclb.uta.edu -C $SNMP_COMMUNITY3$ -x memoryAvailabilityStatus -w 100 -c 1000
SNMP memoryAvailabilityStatus OK: 1 = 1Code: Select all
command_name check_ironport.pl
command_line $USER1$/check_ironport.pl -H $HOSTADDRESS$ -C $SNMP_COMMUNITY3$ -x $ARG1$ -w $ARG2$ -c $ARG3$
Thanks in advance
Chris
