Confused.."It appears as though you do not have permission."
tb1985
Post by tb1985 »
Hi
I've just installed Nagios core from the EPEL repository on CentOS 7.
I modified the included Apache config file to authenticate to our LDAP database with a restricted set of users. Apache is sufficiently protecting our Nagios.
The issue is that I have three users: nagiosadmin (predefined), then teddy, and steve (both from LDAP). Using the configuration below, teddy has full access to Nagios but steve gets messages like "It appears as though you do not have permission to view information for any of the hosts you requested..."
I can't find any rhyme or reason. The contactgroup named admins doesn't seem to be referenced anywhere but the notifications. When I add steve to the contactgroup named admins he has full access.
This is in /etc/nagios/objects/contacts.cfg (included by nagios.conf)
define contact{
  contact_name nagiosadmin             ; Short name of user
  use generic-contact         ; Inherit default values from generic-contact template (defined above)
  alias Nagios Admin            ; Full name of user
  email [email protected]    ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS *****
define contact {
  contact_name teddy
  use generic-contact
  alias Teddy User
define contact {
  contact_name steve
  use generic-contact
  alias Steve User
define contactgroup{
  contactgroup_name admins
  alias Nagios Administrators
  members nagiosadmin,teddy
and in /etc/nagios/cgi.cfg, I added default_user_name=nagiosadmin (all permissions are assigned to nagiosadmin).
Any help is appreciated, thanks.
npolovenko
Re: Confused.."It appears as though you do not have permissi
Post by npolovenko »
Hello, @tb1985. Could you post the whole cgi.cgf file either in this thread or send to me in a private message? If you send it in a private message please write something in this thread to bring it back up in the support queue.
tb1985
Post by tb1985 »
Thanks. File is attached.
cgi.cfg
(12.69 KiB) Downloaded 564 times
npolovenko
@tb1985, Try changing all the following lines in cgi.cfg file by replacing "=nagiosadmin" with "=*":
authorized_for_system_information=*
authorized_for_configuration_information=*
authorized_for_system_commands=*
authorized_for_all_services=*
authorized_for_all_hosts=*
authorized_for_all_service_commands=*
authorized_for_all_host_commands=*
When done go ahead and restart the nagios server, as well as the apache:
service httpd restart
 service nagios restart
tb1985
Post by tb1985 »
I had considered that but I'd rather have a better understanding of what is happening.
Why does my user "teddy" have access without being specified in cgi.conf?
Removing myself from the admins contactgroup revokes my access, but adding it to the admins contactgroup grant it. I don't understand why.
Anyway, I did as suggested and we are OK now. Will see if I can read the docs to understand how permissions are applied better.
npolovenko
@tb1985, Probably because all hosts and services are subscribed to the admins contact group by default with the installation. Take a look at your service and host definitions and you'll probably see a lot of:
contact_groups		admins		;
If your hosts and services inherit from templates then I'd take a look at the templates.
By default, unless you modify the cgi.cgf file a particular contact can only see hosts and services that have him as a contact. Does this make sense? Wherever its:
or
contacts admins
tb1985
Post by tb1985 »
Ah that's the missing link. I'm using templates for all my services which includes contact_groups admins.
Thanks for your help!
npolovenko
@tb1985, Glad I could help. I will be closing this thread as resolved.
