Nagios XI installation error
MOHANREDDY
Post by MOHANREDDY »
I am trying to install NagiosXI on Rhel 7.3 in an offline environment using offline installation document. I have installed all the pre required packages and tried to install but i ran into error.
Error: Package: perl-Nagios-Monitoring-Plugin-0.51-1.el7.noarch (/perl-Nagios-Monitoring-Plugin-0.51-1.el7.noarch)
Requires: perl(Math::Calc::Units)
yum can be configured to try to resolve such errors by temporarily enabling
disabled repos and searching for missing dependencies.
To enable this functionality please set 'notify_only=0' in /etc/yum/pluginconf.d/search-disabled-repos.conf
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Uploading Enabled Repositories Report
Loaded plugins: langpacks, product-id, versionlock
Please help me in resolving the issue.
Re: Nagios XI installation error
See a solution for the same issue here: https://support.nagios.com/forum/viewto ... 11#p251211
