monitoring routers and switches
kazishe
Post by kazishe »
Hello all.
Hope you can help me here. I am trying to monitor several routers and switches. I have just installed Nagios Core 4.3.4 which is working perfectly, and have followed the guide on https://assets.nagios.com/downloads/nag ... uters.html and yet this looks like it is for monitoring one switch or router. I have tried adding a new line for a new device and get errors there, so I am wondering if I am supposed to add all the routers and switches in the switch.cfg?
Thank you for your help.
Re: monitoring routers and switches
This whole document is an example for 1 switch, and the configurations for it.
You would need to basically create a new version changing all the host names and everything, for each switch and for example, place them in a file called switch2.cfg where you would then add that line to your nagios.cfg
cfg_file=/usr/local/nagios/etc/objects/switch2.cfg
Then restart nagios.
additionally, this assumes you are monitoring each of these switches with MRTG already.
If you were using Nagios XI, it becomes MUCH easier, you just run a quick wizard
Here's a video
https://www.nagios.com/videos/?video=iF ... FNij0mkwm8
