"Apply Configuration" never applies
Johnsmit
Post by Johnsmit »
i took a backup of server1 (Rhel 7.3) and applied it on server2 (Rhel 7.3) , everything is fine but when i tries to apply configuration, it never ends and throws .
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Local disk.cfg', starting on line 16)
On server:
find / -name 'Local disk.cfg'
find: '/softlib/instlib/Linux/WSRR/ansible': Permission denied
./reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=jNJ0d38KRDij' -O nagiosql.login--2018-05-14 14:27:49-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... 127.0.0.1
Connecting to localhost (localhost)|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: 'nagiosql.login'
[ <=> ] 37,280 --.-K/s in 0.01s
2018-05-14 14:27:50 (3.36 MB/s) - 'nagiosql.login' saved [37280]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=jNJ0d38KRDij' -O nagiosql.login--2018-05-14 14:27:50-- http://localhost/nagiosxi/includes/components/ccm/
2018-05-14 14:27:50 (3.72 MB/s) - 'nagiosql.login' saved [37280]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
Saving to: 'nagiosql.export.monitoring'
[ <=> ] 21,806 --.-K/s in 0.008s
2018-05-14 14:27:51 (2.50 MB/s) - 'nagiosql.export.monitoring' saved [21806]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 49 services.
Checked 3 hosts.
Checked 3 host groups.
Checked 0 service groups.
Checked 8 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 13 time periods.
Checked 0 host escalations.
Checked 3 hosts
Checked 0 host dependencies
Checked 13 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
help in solving the issue.
Re: "Apply Configuration" never applies
Go to Configure -> CCM -> Services
From the template name drop down select "Local disk"
click the disk icon next to any service in the list.
The object definition stat starts on line 16 is missing either hosts, or a service description
Johnsmit
Post by Johnsmit »
one of the other posts in nagios support helped me to solve the issue. you can close this thread.
Locking
