Hi Team,
we have successfully integrate with AD but unable to view all users on single page. hence we are unable to give access of particular users.
Kindly help me on this.
unable to view all users ID after AD intigration
ganeshkagde
Re: unable to view all users ID after AD intigration
You may be running into the issue described in https://support.nagios.com/kb/article/a ... n-600.html under the "Not All Active Directory Users Are Listed" section. Please review this for a solution.
I would also point out that the directory browser isn't technically needed to add a user from AD or LDAP. If you know the users information, you can simply add them under Admin > Users > Manage Users, select the appropriate auth type from the drop down, fill in the required info, and be good to go.
Another option would be to use the API to add users. I just posted details on this today at https://support.nagios.com/forum/viewto ... ilit=+ldap.
ganeshkagde
i am not able to see "viewtopic.php?f=16&t=48605&hilit=+ldap." this link, as i am getting below message.
"You are not authorised to read this forum."
I've shared the contents of his post here:
cdienger wrote:This can be done with some additional parameters sent to the system/user endpoint. Example:
curl -XPOST "https://nagios/nagiosxi/api/v1/system/u ... >&pretty=1" -d "username=adusertest&password=test&name=Alice%20Testuser&email=[email protected]&auth_level=admin&auth_type=ad&ldap_ad_dn=CN=Alice,CN=Users,DC=acme,DC=local&ldap_ad_username=alice&auth_server_id=auth_server_id" --insecure
The auth_server_id can be found by running:
echo "select * from xi_options where name='ldap_ad_integration_component_servers';" | mysql -uroot -pnagiosxi -Dnagiosxi
and running the value returned through a tool like https://www.base64decode.org/ .
The usual API system/user endpoint parameters can be found under Help > REST API Docs > System Reference of the XI interface.
ganeshkagde
Hi Team,
Thanks for your help and support, you may now proceed to close this case.
kyang
Sounds good!
Thanks for using the Nagios Support Forums!
Feel free to create a new thread if you have any more issues.
Have a great day!
Have a great day!
