I've just installed Nagios network analyzer and I'm having issues starting the source. I initially restarted the nagiosna process and this got the process started but it's not showing any data being collected even though I have "Successfully reaped nfcapd file" in the backend logs. I also cannot stop or delete the source. I have tried following the troubleshooting guide found here:
https://support.nagios.com/kb/pdf-31.html
I still can't get this to work. Any ideas why this is happening? This is the second time I installed nna to try and get around the issue but still no luck.
Many thanks!
Source won't start automatically
Re: Source won't start automatically
What port number did you select?
If you go to the sources page does it show as red Stopped in the status column?
