'Servicename': Not found error
We are getting 'Servicename': Not found error in one of our servers.
We did test check command in service, it is working fine.
Also we crosschecked it using putty where also it is working fine(PFB output)-
[nagios@nagiosserver libexec]$ ./check_nt -H remoteserver -s "password" -p 12489 -v SERVICESTATE -l 'Servicename' -d SHOWALL
Servicename: Started
Please let us know why we are getting 'Servicename': Not found error in Nagios GUI.
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: 'Servicename': Not found error
does servicename contain any non-alpha chars?
Can you share the config from the CCM for this service?
Hello Scott,
I've attached the configs.
Thanks!
Thanks!
Thanks & Regards,
I2MP Team.
I2MP Team.
The $ is going to need special escaping
See this article
https://support.nagios.com/kb/article/n ... s-580.html
See this article
I referred the KB, but the backslash did not help. I noticed when I run the 'Test Check Command' it takes the backslash on it's own, you can find it in the snapshot attached.
Thanks & Regards,
I2MP Team.
I2MP Team.
That looks like you got a proper response.
In this post the backslash wasn't present
https://support.nagios.com/forum/viewto ... 35#p252147
Although I am getting a proper response in the Test Check Command, the error is not resolved yet. The service still shows critical. I am attaching the Service config from CCM, the result of Test Check Command and the Error I get on the service.
Thanks & Regards,
I2MP Team.
I2MP Team.
In $ARG3$ change
to
the test command performs some escaping that may not allow the "real" command to run. this is required to prevent command injection form apache although the command may run correct once nagios is executing it.
$Code: Select all
\$Re: 'Servicename': Not found error
Hey,
You should use single quotation for SQL service names.
In your case ARG3 would be -
-l 'SQLAgent$REMEA_LANDESK' or -l 'SQLAgent$REMEA_LANDESK' -d SHOWALL
Try both and let us know the result.
Yes this can work also, but it all depends on how the command is configured.sac1472 wrote:In your case ARG3 would be -
