We have to disable EH on NAGIOS server when NAGIOS got crashed so we can decrease the load on the server.
However, when we do that from the GUI, then after some time it gets enabled on its own. Any idea please what is the reason?
We tried even via the CMD to modify some parameters like:
egrep -i "accept_passive_service_checks|retain_state_information" /usr/local/nagios/etc/nagios.cfg
accept_passive_service_checks=0
retain_state_information=0
Also we were not sure if this really can disable the EH or not as the GUI does not give correct information.
Any help please?
Nabi
Disable EH on NAGIOS
Re: Disable EH on NAGIOS
https://assets.nagios.com/downloads/nag ... t_handlers has information on disabling event handlers. Note that you may need to also disable state retention if it is enabled.
Thanks, yeah we were trying with these options, but it seems on the GUI for some reason it gets enabled on its own after some time.
So i am not sure if we still miss some option or we have some other issue..
Nabi
Nabi
Can you provide a copy of your nagios.cfg after you've edited it to disable event handlers?
Ok, if i could ask the question differently for now.
If we disable the EH via external command like this:
now=`date +%s`
commandfile='/usr/local/nagios/var/rw/nagios.cmd'
/usr/bin/printf "[%lu] DISABLE_EVENT_HANDLERS\n" $now > $commandfile
Is there any way please to show that EH is really disabled?
Nabi
now=`date +%s`
Nabi
You can just run:
or
if you are using ramdisk
or
You should see:
grep enable_event_handlers /usr/local/nagios/var/status.datCode: Select all
grep enable_event_handlers /var/nagiosramdisk/status.dator
grep enable_event_handlers /custom/path/to/the/status.datCode: Select all
enable_event_handlers=0Be sure to check out our Knowledgebase for helpful articles and solutions!
