I was importing all the configs using import comfig option and using guidelines from the screen.
Most of the configs get loaded with no issues but after I import all the services now I get an error importing timeperiods.cfg
could not parst line # 1 on linenumber 358
Migrating from Nagios XI Version : 2014R1.5 to Nagios XI Ver
npolovenko
- Support Tech
Re: Migrating from Nagios XI Version : 2014R1.5 to Nagios XI
Hello, @sujitt. Can you share the timeperiods.cfg file with us?
Did you follow this order when importing the configs?
Time Periods needed to be imported before services.
I finally resolved this issue. The problem was with lot of the names had space in it and had to be renamed.
You can close this issue.
