Is there any way of creating dynamically services of the same type, depending on the result of some previous check? I would like to first check the number of devices attached to a remote host, and then for each discovered device define a service check. For example, I am monitoring a number of hosts which have various numbers of GPU cards installed. I would like to check how many cards are there and for each card send a detailed check.
Create service instance dynamically
Re: Create service instance dynamically
This wouldn't be possible in Nagios Core as there is no API to write configuration files (maybe you could create new files in a conf_dir directory ).
It would be possible in Nagios XI as there is a configuration API, although you would need to still write the logic to create it.
