Mass import of Service Templates in Nagios XI?
riahc3
Post by riahc3 »
Ive found out about importing service templates into Nagios XI and I want to go ahead and use the functionality.
I thought that putting a file in "/usr/local/nagios/etc/import" and then running "/usr/local/nagiosxi/scripts/reconfigure_nagios.sh" it would automatically import it...but I dont see any indication in Nagios XI that does this.
I didnt get any error message when I ran the script.
The file is like so:
name Check Some Service Service Template
service_description Check Some Service Service Template
check_command check_nrpe!check_service!-n -a 'service=service' 'warn=none' "crit=state='stopped'"!!!!!!
register 0
name Check Some Service Process Template
service_description Check Some Service Process Template
check_command check_nrpe!check_process!-n -a 'process=service.exe' 'show-all'!!!!!!
register 0
I would have expected the service templates menu to be populated but nothing…
How can I correctly import all these?
Re: Mass import of Service Templates in Nagios XI?
I did exactly this, placed the following in /usr/local/nagios/etc/import/templates.cfg
register 0
register 0
ran Apply Configuration through the UI
There were no errors
If I go to Configure -> CCM -> Service Templates
Upper right Search for "Check Some Service Service Template" OR "Check Some Service Process Template"
I see the newly imported template
riahc3
Post by riahc3 »
Is the name of the file important?
Not really, as long as it is in the /usr/local/nagios/etc/import/ directory (and is a valid file) it should import no matter what it is named.
