NRPE install problem
nik.vu
Post by nik.vu »
Hi all,
I have a little problem with nrpe installation from this document.
This is the actual error that apears when i try to install.
cd ./src/; make
make[1]: Entering directory '/tmp/linux-nrpe-agent/subcomponents/nrpe/nrpe-3.2.1/src'
gcc -g -O2 -I/usr/include/openssl -DHAVE_CONFIG_H -I ../include -I ./../include -o nrpe ./nrpe.c ./utils.c ./acl.c -L/usr/lib/x86_64-linux-gnu/  -lssl -lcrypto -lnsl -lwrap
In file included from ./nrpe.c:45:0:
./../include/dh.h: In function 'get_dh2048':
./../include/dh.h:36:4: error: dereferencing pointer to incomplete type 'DH {aka struct dh_st}'
  dh->p=BN_bin2bn(dh2048_p,sizeof(dh2048_p),NULL);
Makefile:48: recipe for target 'nrpe' failed
make[1]: * [nrpe] Error 1
make[1]: Leaving directory '/tmp/linux-nrpe-agent/subcomponents/nrpe/nrpe-3.2.1/src'
Makefile:65: recipe for target 'all' failed
make: * [all] Error 2
cd ./src/; make install
make install-plugin
make[2]: Entering directory '/tmp/linux-nrpe-agent/subcomponents/nrpe/nrpe-3.2.1/src'
/usr/bin/install -c -m 755 -d /usr/local/nagios/bin
/usr/bin/install -c -m 755 ../uninstall /usr/local/nagios/bin/nrpe-uninstall
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios check_nrpe /usr/local/nagios/libexec
/usr/bin/install: cannot stat `check_nrpe': No such file or directory
Makefile:58: recipe for target 'install-plugin' failed
make[2]: * [install-plugin] Error 1
make[2]: Leaving directory '/tmp/linux-nrpe-agent/subcomponents/nrpe/nrpe-3.2.1/src'
Makefile:54: recipe for target 'install' failed
make[1]: * [install] Error 2
Makefile:89: recipe for target 'install' failed
make: * [install] Error 2
Stopping internet superserver: xinetd.
Starting internet superserver: xinetd.
NRPE-POST
sed: can't read /etc/xinetd.d/nrpe: No such file or directory
real    5m36.327s
user    5m25.168s
sys     0m6.832s
INSTALLING EXTRA PLUGINS...
real    0m0.014s
user    0m0.004s
sys     0m0.004s
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
Just to mention, this installation only fail when i try to install on some minimal Linux Box(Debian 7). This Linux Box is used only for some Asterisk voip setup, and i need this nrpe for some asterisk checks, sip_peers and others.
Do you have some advice? Is it possible thats this erros happens because of limitations of this Linux Box, because everything is ok when i install on clean Debian system?
Thanks for your attention. I’m looking forward to your reply.
npolovenko
Re: NRPE install problem
Post by npolovenko »
Hello, @nik.vu . Some compiling package could be missing. Please run the following command to install the prereqs:
yum install -y gcc glibc glibc-common openssl openssl-devel perl wget
nik.vu
Post by nik.vu »
Thanks @npolovenko.
You can close this topic.
