Nagios Core re-installation
charangandra
Post by charangandra »
I am trying to re-install Nagios core on Centos 7 and I am getting below error during the installation process.
Any help is greately appreciated.
Command ran was@
make install
Error details are below:
cd ./base && make install
make[1]: Entering directory `/tmp/nagioscore-nagios-4.3.4/base'
make install-basic
make[2]: Entering directory `/tmp/nagioscore-nagios-4.3.4/base'
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/bin
/bin/install -c -m 774 -o nagios -g nagios nagios /usr/local/nagios/bin
/bin/install -c -m 774 -o nagios -g nagios nagiostats /usr/local/nagios/bin
make[2]: Leaving directory `/tmp/nagioscore-nagios-4.3.4/base'
make strip-post-install
/bin/strip /usr/local/nagios/bin/nagios
/bin/strip /usr/local/nagios/bin/nagiostats
make[1]: Leaving directory `/tmp/nagioscore-nagios-4.3.4/base'
cd ./cgi && make install
make[1]: Entering directory `/tmp/nagioscore-nagios-4.3.4/cgi'
make install-basic
make[2]: Entering directory `/tmp/nagioscore-nagios-4.3.4/cgi'
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/sbin
for file in *.cgi; do \
/bin/install -c -m 775 -o nagios -g nagios $file /usr/local/nagios/sbin; \
done
make[2]: Leaving directory `/tmp/nagioscore-nagios-4.3.4/cgi'
/bin/strip /usr/local/nagios/sbin/$file; \
done
make[1]: Leaving directory `/tmp/nagioscore-nagios-4.3.4/cgi'
cd ./html && make install
make[1]: Entering directory `/tmp/nagioscore-nagios-4.3.4/html'
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/media
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/stylesheets
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/contexthelp
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs/images
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/js
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images/logos
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includes
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/ssi
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/angularjs
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/angularjs/angular-1.3.9
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/angularjs/ui-utils-0.2.1
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/bootstrap-3.3.0
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/bootstrap-3.3.0/css
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/d3
/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/spin
/bin/install -c -m 664 -o nagios -g nagios robots.txt /usr/local/nagios/share
rm -f /usr/local/nagios/share/index.html
rm -f /usr/local/nagios/share/main.html
rm -f /usr/local/nagios/share/side.html
rm -f /usr/local/nagios/share/map.html
rm -f /usr/local/nagios/share/rss-*
rm -rf /usr/local/nagios/share/include/rss
/bin/install -c -m 664 -o nagios -g nagios jsonquery.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios graph-header.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios histogram.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios histogram-form.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios histogram-graph.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios histogram-links.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios infobox.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios map.php /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios map-directive.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios map-form.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios map-links.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios map-popup.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends-form.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends-graph.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends-host-yaxis.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends-links.html /usr/local/nagios/share
/bin/install -c -m 664 -o nagios -g nagios trends-service-yaxis.html /usr/local/nagios/share
for file in *.php; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share; done
for file in stylesheets/*.css; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/stylesheets; done
for file in contexthelp/*.html; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/contexthelp; done
for file in js/*.js; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/js; done
for file in images/*.gif; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/images; done
for file in images/*.jpg; \
for file in images/*.png; \
for file in images/*.ico; \
for file in images/logos/*.*; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/images/logos; done
for file in includes/*.*; \
do /bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/includes; done
/bin/install -c -m 664 -o nagios -g nagios angularjs/angular-1.3.9/angular.min.js /usr/local/nagios/share/angularjs/angular-1.3.9
/bin/install -c -m 664 -o nagios -g nagios angularjs/angular-1.3.9/angular.min.js.map /usr/local/nagios/share/angularjs/angular-1.3.9
/bin/install -c -m 664 -o nagios -g nagios angularjs/ui-bootstrap-tpls-0.12.0.min.js /usr/local/nagios/share/angularjs
/bin/install -c -m 664 -o nagios -g nagios angularjs/ui-utils-0.2.1/ui-utils.js /usr/local/nagios/share/angularjs/ui-utils-0.2.1
/bin/install -c -m 664 -o nagios -g nagios bootstrap-3.3.0/css/bootstrap.min.css /usr/local/nagios/share/bootstrap-3.3.0/css
/bin/install: cannot stat ‘bootstrap-3.3.0/css/bootstrap.min.css’: No such file or directory
make[1]: *** [install] Error 1
make[1]: Leaving directory `/tmp/nagioscore-nagios-4.3.4/html'
make: *** [install] Error 2
Charan
Re: Nagios Core re-installation
Post by mcapra »
Did you run make all in advance of make install? The make all step is what extracts the bootstrap/angular/etc packages:
[root@capra_nag nagios-4.3.4]# make all | grep bootstrap
   creating: angular-1.3.9/docs/components/bootstrap-3.1.1/
   creating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap-theme.css
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap-theme.css.map
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap-theme.min.css
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap.css
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap.css.map
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/css/bootstrap.min.css
   creating: angular-1.3.9/docs/components/bootstrap-3.1.1/fonts/
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/fonts/glyphicons-halflings-regular.eot
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/fonts/glyphicons-halflings-regular.svg
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/fonts/glyphicons-halflings-regular.ttf
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/fonts/glyphicons-halflings-regular.woff
   creating: angular-1.3.9/docs/components/bootstrap-3.1.1/js/
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/js/bootstrap.js
  inflating: angular-1.3.9/docs/components/bootstrap-3.1.1/js/bootstrap.min.js
   creating: angular-1.3.9/docs/js/angular-bootstrap/
  inflating: angular-1.3.9/docs/js/angular-bootstrap/bootstrap.js
  inflating: angular-1.3.9/docs/js/angular-bootstrap/bootstrap.min.js
  inflating: angular-1.3.9/docs/js/angular-bootstrap/bootstrap.min.js.map
  inflating: angular-1.3.9/docs/js/angular-bootstrap/dropdown-toggle.js
  inflating: angular-1.3.9/docs/js/angular-bootstrap/dropdown-toggle.min.js
  inflating: angular-1.3.9/docs/js/angular-bootstrap/dropdown-toggle.min.js.map
  inflating: angular-1.3.9/docs/partials/api/ng/function/angular.bootstrap.html
  inflating: angular-1.3.9/docs/partials/guide/bootstrap.html
if [ ! -d bootstrap-3.3.0 ] ; then mkdir -p bootstrap-3.3.0 && ( cd bootstrap-3.3.0 && unzip -u ../bootstrap-3.3.0-dist.zip && mv dist/* . && rmdir dist ) ; fi
Archive:  ../bootstrap-3.3.0-dist.zip
  inflating: dist/css/bootstrap-theme.css
  inflating: dist/css/bootstrap-theme.css.map
  inflating: dist/css/bootstrap-theme.min.css
  inflating: dist/css/bootstrap.css
  inflating: dist/css/bootstrap.css.map
  inflating: dist/css/bootstrap.min.css
  inflating: dist/js/bootstrap.js
  inflating: dist/js/bootstrap.min.js
You might try running make all again.
