[2018-05-24 16:41:02,462][DEBUG][action.search.type ] [41b94e87-cf97-48ac-a5c6-ed795f9e33f2] All shards failed for phase: [query]
org.elasticsearch.transport.RemoteTransportException: [a1d229b5-12fa-4c5e-8d5b-746ece0d27aa][inet[/10.50.30.107:9300]][indices:data/read/search[phase/query]]
Caused by: org.elasticsearch.ElasticsearchException: org.elasticsearch.common.breaker.CircuitBreakingException: [FIELDDATA] Data too large, data for [host.raw] would be larger than limit of [13450084352/12.5gb]
at org.elasticsearch.index.fielddata.plain.AbstractIndexFieldData.load(AbstractIndexFieldData.java:80)
at org.elasticsearch.search.aggregations.support.ValuesSource$MetaData.load(ValuesSource.java:88)
at org.elasticsearch.search.aggregations.support.AggregationContext.bytesField(AggregationContext.java:180)
at org.elasticsearch.search.aggregations.support.AggregationContext.valuesSource(AggregationContext.java:143)
at org.elasticsearch.search.aggregations.support.ValuesSourceAggregatorFactory.create(ValuesSourceAggregatorFactory.java:53)
at org.elasticsearch.search.aggregations.AggregatorFactories.createAndRegisterContextAware(AggregatorFactories.java:53)
at org.elasticsearch.search.aggregations.AggregatorFactories.createTopLevelAggregators(AggregatorFactories.java:157)
at org.elasticsearch.search.aggregations.AggregationPhase.preProcess(AggregationPhase.java:79)
at org.elasticsearch.search.query.QueryPhase.execute(QueryPhase.java:100)
at org.elasticsearch.search.SearchService.loadOrExecuteQueryPhase(SearchService.java:301)
at org.elasticsearch.search.SearchService.executeQueryPhase(SearchService.java:312)
at org.elasticsearch.search.action.SearchServiceTransportAction$SearchQueryTransportHandler.messageReceived(SearchServiceTransportAction.java:776)
at org.elasticsearch.search.action.SearchServiceTransportAction$SearchQueryTransportHandler.messageReceived(SearchServiceTransportAction.java:767)
at org.elasticsearch.transport.netty.MessageChannelHandler$RequestHandler.doRun(MessageChannelHandler.java:279)
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:36)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.elasticsearch.common.util.concurrent.UncheckedExecutionException: org.elasticsearch.common.breaker.CircuitBreakingException: [FIELDDATA] Data too large, data for [host.raw] would be larger than limit of [13450084352/12.5gb]
at org.elasticsearch.common.cache.LocalCache$Segment.get(LocalCache.java:2203)
at org.elasticsearch.common.cache.LocalCache.get(LocalCache.java:3937)
at org.elasticsearch.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4739)
at org.elasticsearch.indices.fielddata.cache.IndicesFieldDataCache$IndexFieldCache.load(IndicesFieldDataCache.java:167)
at org.elasticsearch.index.fielddata.plain.AbstractIndexFieldData.load(AbstractIndexFieldData.java:74)
... 17 more
Caused by: org.elasticsearch.common.breaker.CircuitBreakingException: [FIELDDATA] Data too large, data for [host.raw] would be larger than limit of [13450084352/12.5gb]
at org.elasticsearch.common.breaker.ChildMemoryCircuitBreaker.circuitBreak(ChildMemoryCircuitBreaker.java:97)
at org.elasticsearch.common.breaker.ChildMemoryCircuitBreaker.addEstimateBytesAndMaybeBreak(ChildMemoryCircuitBreaker.java:148)
at org.elasticsearch.index.fielddata.plain.PagedBytesIndexFieldData$PagedBytesEstimator.beforeLoad(PagedBytesIndexFieldData.java:217)
at org.elasticsearch.index.fielddata.plain.PagedBytesIndexFieldData.loadDirect(PagedBytesIndexFieldData.java:89)
at org.elasticsearch.index.fielddata.plain.PagedBytesIndexFieldData.loadDirect(PagedBytesIndexFieldData.java:43)
at org.elasticsearch.indices.fielddata.cache.IndicesFieldDataCache$IndexFieldCache$1.call(IndicesFieldDataCache.java:180)
at org.elasticsearch.indices.fielddata.cache.IndicesFieldDataCache$IndexFieldCache$1.call(IndicesFieldDataCache.java:167)
at org.elasticsearch.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:4742)
at org.elasticsearch.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at org.elasticsearch.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at org.elasticsearch.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at org.elasticsearch.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
... 21 moreCode: Select all
Date # Docs Index Size (GB)
2018.04.24 80,123,435 23.80
2018.04.25 79,154,864 23.30
2018.04.26 75,573,485 21.90
2018.04.27 72,603,365 20.90
2018.04.28 13,752,469 3.90
2018.04.29 11,210,996 3.30
2018.04.30 34,017,591 12.00
2018.05.01 30,140,906 10.70
2018.05.02 27,746,199 9.80
2018.05.03 21,758,601 7.60
2018.05.04 31,733,987 12.10
2018.05.05 8,342,020 2.90
2018.05.06 8,754,301 3.10
2018.05.07 39,043,424 15.10
2018.05.08 37,447,506 14.40
2018.05.09 36,286,876 13.70
2018.05.10 39,211,018 14.60
2018.05.11 34,709,762 12.40
2018.05.12 11,404,047 3.50
2018.05.13 11,151,603 3.30
2018.05.14 44,699,775 16.70
2018.05.15 46,745,086 17.50
2018.05.16 33,705,539 12.10
2018.05.17 30,380,948 10.90
2018.05.18 27,627,349 10.10
2018.05.19 8,345,161 2.80
2018.05.20 7,643,582 2.60
2018.05.21 36,876,143 13.70
2018.05.22 36,335,297 13.20
2018.05.23 37,057,332 13.10
2018.05.24 17,505,744 6.60
