I am unable to Apply any configuration. I always get stuck in "Waiting for configuration verification..." -screen. I have already done everything stated in this KB: https://support.nagios.com/kb/article.php?id=34 . The problem still persists. I am using Nagios XI 5.4.13 installed on CentOS 7 1804 64 Bit. I've installed it manually since there is no Internet connection on the server. Can anyone help me?
Can't Apply Configuration
Re: Can't Apply Configuration
Can you share the output of the following commands executed from the CLI of your Nagios XI machine:
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
su nagios
exit
Yes I can,
[root@nagios tmp]# /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=HKlXQiLGDEke' -O nagiosql.login--2018-05-26 19:58:46-- http://localhost/nagiosxi/includes/components/ccm/
Auflösen des Hostnamen »localhost (localhost)«... ::1, 127.0.0.1
Verbindungsaufbau zu localhost (localhost)|::1|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: nicht spezifiziert [text/html]
In »»nagiosql.login«« speichern.
[ <=> ] 29.726 --.-K/s in 0,02s
2018-05-26 19:58:47 (1,22 MB/s) - »nagiosql.login« gespeichert [29726]
LOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
[0] => 192.168.2.107.cfg
[1] => BFjO9jif.tmp.cfg
IMPORTING /usr/local/nagios/etc/import/192.168.2.107.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=admin&type=import&importsubmitted=true&chbOverwrite=1&subForm=Import&selImportFile[]=/usr/local/nagios/etc/import/192.168.2.107.cfg' -O nagiosql.import.monitoring
--2018-05-26 19:58:47-- http://localhost/nagiosxi/includes/components/ccm/
In »»nagiosql.import.monitoring«« speichern.
[ <=> ] 26.373 --.-K/s in 0,02s
2018-05-26 19:58:47 (1,16 MB/s) - »nagiosql.import.monitoring« gespeichert [26373]
IMPORTING /usr/local/nagios/etc/import/BFjO9jif.tmp.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=admin&type=import&importsubmitted=true&chbOverwrite=1&subForm=Import&selImportFile[]=/usr/local/nagios/etc/import/BFjO9jif.tmp.cfg' -O nagiosql.import.monitoring
--2018-05-26 19:58:48-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 26.224 --.-K/s in 0,02s
2018-05-26 19:58:48 (1,07 MB/s) - »nagiosql.import.monitoring« gespeichert [26224]
RESETTING PERMS
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=HKlXQiLGDEke' -O nagiosql.login--2018-05-26 19:58:48-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 29.809 --.-K/s in 0,02s
2018-05-26 19:58:49 (1,35 MB/s) - »nagiosql.login« gespeichert [29809]
LOGIN SUCCESSFUL!
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2018-05-26 19:58:49-- http://localhost/nagiosxi/includes/components/ccm/
In »»nagiosql.export.monitoring«« speichern.
[ <=> ] 21.966 --.-K/s in 0,01s
2018-05-26 19:58:50 (1,98 MB/s) - »nagiosql.export.monitoring« gespeichert [21966]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 44 services.
Checked 5 hosts.
Checked 1 host groups.
Checked 0 service groups.
Error: Contact 'Amelie Franz' has no service notification commands defined!
Error: Contact 'Amelie Franz' has no host notification commands defined!
Warning: Contact 'Amelie Franz' has no service notification time period defined!
Warning: Contact 'Amelie Franz' has no host notification time period defined!
Error: Contact 'Ashley Clancy' has no service notification commands defined!
Error: Contact 'Ashley Clancy' has no host notification commands defined!
Warning: Contact 'Ashley Clancy' has no service notification time period defined!
Warning: Contact 'Ashley Clancy' has no host notification time period defined!
Error: Contact 'Christian Plesser' has no service notification commands defined!
Error: Contact 'Christian Plesser' has no host notification commands defined!
Warning: Contact 'Christian Plesser' has no service notification time period defined!
Warning: Contact 'Christian Plesser' has no host notification time period defined!
Error: Contact 'Eugen Gärtner' has no service notification commands defined!
Error: Contact 'Eugen Gärtner' has no host notification commands defined!
Warning: Contact 'Eugen Gärtner' has no service notification time period defined!
Warning: Contact 'Eugen Gärtner' has no host notification time period defined!
Error: Contact 'Holger Einheuser' has no service notification commands defined!
Error: Contact 'Holger Einheuser' has no host notification commands defined!
Warning: Contact 'Holger Einheuser' has no service notification time period defined!
Warning: Contact 'Holger Einheuser' has no host notification time period defined!
Error: Contact 'Ronan Moeller' has no service notification commands defined!
Error: Contact 'Ronan Moeller' has no host notification commands defined!
Warning: Contact 'Ronan Moeller' has no service notification time period defined!
Warning: Contact 'Ronan Moeller' has no host notification time period defined!
Checked 8 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 5 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 12
Total Errors: 12
***> One or more problems was encountered while running the pre-flight check...
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /tmp
tar: Entferne führende „/“ von Elementnamen
/tmp
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1527147203.tar.gz
/ /tmp
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1527147203.tar.gz
/tmp
RESETTING PERMS
[root@nagios tmp]# su nagios
bash-4.2$ /usr/local/nagiosxi/scripts/reconfigure_nagios.sh
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://loca lhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'subm it=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=H KlXQiLGDEke' -O nagiosql.loginnagiosql.login: Keine Berechtigung
LOGIN SUCCESSFUL!
NAGIOSQL LOGIN FAILED!
CMDLINE
LOGIN SUCCESSFUL!
Array
CMDLINE:
CMDLINE:
RESETTING PERMS
CMDLINE
LOGIN SUCCESSFUL!
CMDLINE:
OUTPUT:
Nagios Core 4.2.4
License: GPL
Checking objects...
Checked 5 hosts.
Checked 8 contacts.
Checked 5 hosts
Total Warnings: 12
Total Errors: 12
RET: 1
/tmp
/ /tmp
/tmp
RESETTING PERMS
CMDLINE
LOGIN SUCCESSFUL!
Try updating the credentials under Admin > System Config > Reset Security Credentials, by clicking "Update Credentials" under Sub-System Credentials and run the reconfigure_nagios script as the nagios user. If it still fails, try entering in new XI subsystem ticket, Config Manager Backend Password, and Nagios Core Backend Password, values and then "Update Credentials" and test again.
