getting error while installing NagiosXl on RHEL 7.4
kgaurav
Post by kgaurav »
I am installing Nagios Xl on RHEL 7.4 box, but unfortunately getting the below error. Please help. (my server is on intranet.)
[root@ip-XX-XXX-X-XXX nagiosxi]# ./fullinstall
LOGIN SUCCESSFUL!
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2018-05-25 04:03:06-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... 127.0.0.1
Connecting to localhost (localhost)|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: ‘nagiosql.export.monitoring’
0K .......... .......... . 2.51M=0.008s
2018-05-25 04:03:07 (2.51 MB/s) - ‘nagiosql.export.monitoring’ saved [21958]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 12 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Error: Unable to write to check_result_path ('/usr/local/nagios/var/spool/checkresults') - Permission denied
Total Warnings: 0
Total Errors: 1
***> One or more problems was encountered while running the pre-flight check...
RET: 1
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /home/birarip/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: cannot access /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './E-importnagiosql'
Re: getting error while installing NagiosXl on RHEL 7.4
Post by mcapra »
The root problem:
Does this machine have any special security hardening in place? That folder should be automatically created and correctly permission'd as part of the installation process.
Can you attach a copy of your install.log as well? You may need to make 1 or 2 more posts on the forums to be allowed to attach things to messages, but dumping it into a post with
 blocks should be fine.
or selinux enabled?
getenforce
