Nagios integration issue, between Nagios core and NagiosNA
radoslaw95
Nagios integration issue, between Nagios core and NagiosNA (Network Analyzer) servers. Please see attached document.
Re: Nagios integration issue, between Nagios core and Nagios
Make sure that both servers - Nagios XI and Nagios Network Analyzer use (or don't use) SSL. If one application uses SSL, but the other one doesn't, the integration will most probably fail.
