Nagios XI generating lots of files using high inodes
Endeavour Energy
We have installed and configured Nagios XI on linux machine.
Issue is not able to login on nagios application not getting any issue.
We checke dan found that Nagios is generation lots of files. Directory /usr/local/nagios/var/spool/xidpe using high inodes.
[root@gdms01vp ~]# cd /usr/local/nagios/var/spool/xidpe/
[root@gdms01vp xidpe]# ls -l | wc -l
830497
Could you please suggest into this.
Rajeev Anand
830497
Rajeev Anand
Re: Nagios XI generating lots of files using high inodes
Make sure that cron service is running. It is normal for nagios to drop files there, but they should get picked up immediately and processed by the perfdataproc cron.
Endeavour Energy
Ran the below command to checked
service crond status
It is showing message crond (pid 2389) is working.
Shall i delete manually all the file generated in /usr/local/nagios/var/spool/xidpe
Please suggest
Please suggest
Endeavour Energy
On screen we are experiencing the below error.
SQL Error [ndoutils] : can't create/write to file /tmp/#sql_8fa_o.MYI
Rajeev Anand
Rajeev Anand
is the disk full?
If not what are the permissions on /tmp
df -hCode: Select all
ls -ld /tmp-
Endeavour Energy
Ran the below command and checked
Shall i delete manually all the file generated in /usr/local/nagios/var/spool/xidpe.
inode is 100% full.
Please suggest
inode is 100% full.
Please suggest
yes, but then you are going to want to see why this cron job isn't running.Endeavour Energy wrote:Shall i delete manually all the file generated in /usr/local/nagios/var/spool/xidpe.
inode is 100% full.
Report the following
chage -l nagios
tail -50 /var/log/cron
tail -50 /usr/local/nagiosxi/var/perfdataproc.log-
Endeavour Energy
Hi
Result of below commands is attached as screenshot
chage -l nagios
Rajeev
chage -l nagios
Rajeev
Ok so there are several problems, first the password is expired for the Nagios user.
You should run the following
Second, you are out of disk space again but this should resolve once you fix the password ageing.
chage -m 0 -M 99999 -I -1 -E -1 nagios
