License Question
aballa
License Question
Post by aballa »
I need an information I have always used Nagios is the first time I would use the version "XI"
I should start the installation but have not yet purchased the license technical times, the product for a while will work like a trial period or need the license. I did not find this information in the manuals.
Re: License Question
When you first install Nagios XI, it begins a free, fully-functional 60-day trial. After that you either need to purchase a license, or you can use the free license which is good for up to 7 hosts.
aballa
Post by aballa »
ok Thanks :D
Did you have further (related) questions or are we good to lock this up?
aballa
Post by aballa »
For the moment is ok , next week i install The product.
I watch a manual. Thanks
