Can I monitor the servers which time which server goes Down by Nagios Core?
Monitor the restart service
Re: Monitor the restart service
Simple ping monitoring should do it
Ping only can tell us about current status of the node. It is Down or up.
I want to see last time when computer went to the Down.
Regards
Regards
If you are monitoring whether it is up or down, then you will know the last time it went down. At least, to within a few minutes (it depends on how frequently you are checking). If you are asking to have Nagios tell you the last time a machine went down, without currently monitoring whether it is up or down, then you could look at the uptime for the machine, using the check_uptime plugin if it's a Linux machine.
