Host showing down and services are up
sandeepatil
Post by sandeepatil »
We found event log as below, for all only for hosts.
Warning: The results of host 'xxxx.xxx.com' are stale by 0d 0h 0m 58s (threshold=0d 0h 10m 0s). I'm forcing an immediate check of the host.
nagios.debug :
[1527855171.336420] [016.1] [pid=46859] Service is OK.
[1527855171.336430] [016.1] [pid=46859] Host is NOT UP, so we'll check it to see if it recovered...
[1527855171.336505] [016.0] [pid=46859] Scheduling a non-forced, active check of host 'host.com' @ Fri Jun 1 08:12:51 2018
[1527855171.336529] [016.0] [pid=46859] Active checks are disabled for this host.
[1527855171.336540] [016.1] [pid=46859] Service did not change state.
[1527855171.336652] [016.1] [pid=46859] Checking service 'service' on host 'host.com' for flapping...
[1527855171.336683] [016.1] [pid=46859] Checking host 'host.com' for flapping...
[1527855171.336701] [016.1] [pid=46859] Host is not flapping (0.00% state change).
[1527855171.337070] [016.1] [pid=46859] Processing check result file: '/usr/local/nagios/var/spool/checkresults/cZl5ipZ'
[1527855171.337706] [016.1] [pid=46859] ** Handling async check result for host 'host.com' from 'check result spool dir'...
[1527855171.337744] [016.0] [pid=46859] Discarding passive host check result because passive host checks are disabled globally.
[1527855171.338050] [016.1] [pid=46859] Processing check result file: '/usr/local/nagios/var/spool/checkresults/clgR8xY'
[1527855171.338649] [016.1] [pid=46859] ** Handling async check result for host 'host.com' from 'check result spool dir'...
[1527855171.338685] [016.0] [pid=46859] Discarding passive host check result because passive host checks are disabled globally.
[1527855171.338999] [016.1] [pid=46859] Processing check result file: '/usr/local/nagios/var/spool/checkresults/ckB6x1u'
[1527855171.339509] [016.1] [pid=46859] ** Handling async check result for host 'host.com' from 'check result spool dir'...
[1527855171.339550] [016.0] [pid=46859] Discarding passive host check result because passive host checks are disabled globally.
[1527855171.339872] [016.1] [pid=46859] Processing check result file: '/usr/local/nagios/var/spool/checkresults/cUKrgNF'
[1527855171.340408] [016.0] [pid=46859] ** Handling check result for service 'service' on host 'host.com' from 'check result spool dir'...
[1527855171.340447] [016.1] [pid=46859] HOST: host.com, SERVICE: service, CHECK TYPE: Passive, OPTIONS: 0, SCHEDULED: No, RESCHEDULE: No, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: FILESYSTEM OK - /var/adm is not mounted on this system
Re: Host showing down and services are up
This looks like you have freshness checking on for 'xxxx.xxx.com with a 60 second freshness threshold.
Lower in your debug log, it looks lie you are receiving a bunch of passive checks but passive host checks are disabled globally.
sandeepatil
We found "Passive Host Check" is disabled, after enabling working fine.
Please close this thread.
Glad to hear it is resolved.
Locking
