Someone has scheduled a downtime for a server on 05-31-2018 10:43:24 but the shows that this has been done at 2018-06-01 14:48
Acknowledgements and Comments
By Someone at 2018-06-01 14:48:49
This host has been scheduled for fixed downtime from 05-31-2018 10:43:24 to 12-31-2018 10:43:24. Notifications for the host will not be sent out during that time period.
Why is that updated?
Acknowledgements and Comments time change
sltn_support
Re: Acknowledgements and Comments time change
Is the time and timezone set correctly on the XI machine? Run 'date' and 'grep timezone /etc/php.ini' to check. You can set the timezone under Admin > System Config > System Settings > General if needed.
sltn_support
yes, that is correct.cdienger wrote:Is the time and timezone set correctly on the XI machine? Run 'date' and 'grep timezone /etc/php.ini' to check. You can set the timezone under Admin > System Config > System Settings > General if needed.
But the post time is changing every time.
Can you provide the output of the commands and clarify what you mean by the "post" time?
