When is the VM image for NagiosXI 2012R2.0 going to be released?
Can you provide us with an ETA? Later this week? Early next week?
NagiosXI 2012R2.0
Re: NagiosXI 2012R2.0
Likely later this week.
However, to get the new version you can always grab the current VM and then from the console as root do the following
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/xi-2011-latest.tar.gz
tar xzf xi-2011-latest.tar.gz
cd /tmp/nagiosxi
./upgradeRe: NagiosXI 2012R2.0
http://library.nagios.com/library/produ ... loads/main
It seems the dates are wrong, the source installer says it was released Feb 6 2011, should this be Feb 6 2012, and the release verions should be 2012R2.0
Am I mistaken? Or there are the correct versions.
We are still building on the 2011 Major release.
The 2012 release will be a major release later this year.
